Underdrive pulleys
Old Sep 19, 2007 | 11:37 AM
Capbyrd's Avatar
Capbyrd
Underdrive pulleys
I did a search and saw a lot of people recommending UP but i didnt see any brands mentioned.
What brand are you running and are you happy with them? How much did they cost? Are you running an alternator underdrive too and if so, do you have a higher output alt?
Thanks everyone.
Old Sep 19, 2007 | 03:38 PM
flareside_thunder's Avatar
flareside_thunder
I've got one pulley on my truck...bought it used it's only the crank pulley and I beleive it's BBK...if you surf E-bay I saw some the other day that wer like 50 bucks for the crank.waterpump, and alt pulleys flat black so they look stock.They do do a great deal of good on the motors.....I used my stock alt...what is that like 75 amps?lol......I think the battery in my truck is going dead though so I'd grab the full set.
Old Sep 19, 2007 | 06:15 PM
Skandocious's Avatar
Skandocious
I've never looked too deep into underdrive pulleys. Can someone explain what they are and how they supposedly help performance?
Old Sep 19, 2007 | 06:27 PM
lostin90s's Avatar
lostin90s
By turning accessories at a slower rate the strain on motor is less. They are fine for on road guys. I had set crank alt and fan on old truck and had no charging,cooling related problems even sitting in traffic down town Pittsburg in june with air on for 2 hrs. .
But at low rpms like off road they be a problem. There is a slight MPG increase . But as for a profomace add not much on mine. But any thing to add to MPG . Mine is a polished set from ebay . I got second hand and no marking could be found. Good luck
Old Sep 19, 2007 | 06:30 PM
Skandocious
That's kind of what I figured. Thats Larry.
Old Sep 19, 2007 | 06:57 PM
Moore558's Avatar
Moore558
They now sell underdrive kits that allow you to still get power and the same alternator output.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MCH%2D1015&N=700+ 4294908331+4294908312+4294924761+4294840126+429481 7292+4294862783+115&autoview=sku
Old Sep 19, 2007 | 07:18 PM
flareside_thunder
Moore, that is the kit.....to compensate for the crank pulley being smaller...they make the alt pulley larger so you still get the same charging capabilities.
Old Sep 19, 2007 | 07:34 PM
DJdemon6696's Avatar
DJdemon6696
do you get those kits for 351w? thats maybe my next investment.. with headers
Old Sep 19, 2007 | 08:46 PM
flareside_thunder
I think someone makes em for windsors but you could probably use the 302 set without difficulty....and they're a little more readily available...
Old Sep 19, 2007 | 09:21 PM
StealthWyvern's Avatar
StealthWyvern
your also forgetting another reason why most people get UDP. Not only are they reduced in size but their generally is a HUGE weight difference. Which makes it noticable. Or well on my car it made a huge different on the low end.
Old Sep 19, 2007 | 09:40 PM
flareside_thunder
Made a huge difference on my 302 as well.....and it depends on which pulleys you get...they come in Billet...aluminum....and steel.....
Old Sep 20, 2007 | 04:27 AM
KDPate's Avatar
KDPate
Check with some of the 5.0 Mustang guys. They usually ahve some up for sale cheap.....
Old Sep 20, 2007 | 12:29 PM
12secondstang's Avatar
12secondstang
Summit Racing has a set of UP that steel. Somewhere around 50 bucks.
