Sponsored by: Real Truck
Replacing Transmission Fluid
Old Sep 19, 2007 | 09:18 AM
hjesq's Avatar
hjesq
Question Replacing Transmission Fluid
I have a 2004, F-350 SD V-10 cc, lb with an auto transmission. The vehicle has 125,000 miles and I do not know the service history. My question is do I replace the trans. oil or continue to drive it as is? The oil does not appear brown or stinky.
HE
Old Sep 19, 2007 | 09:33 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, you should replace the fluid and filter.
Old Sep 19, 2007 | 10:10 AM
GregN's Avatar
GregN
Yes, change it. It is better to know exactly what is going on in your truck rather than guessing. Doing an oil analysis wouldn't be a bad idea either. Just my .02
I have heard against using AMSOIL ATF for the Superduty Transmissions. I have an Early 99 Super Duty with the 7.3L. I like AMSOIL, but I have heard that they cause this transmission to slip excessively. Any insight would be appreciated. This subject was touched briefly in another post.
Old Sep 19, 2007 | 12:22 PM
ReAX's Avatar
ReAX
I concur, might as well change out all of the fluids and have a base line for future maintenance.
I am using Royal Purple ATF and with my tune and factory tech valve body, no slipping. In fact with the valve body and RP, I am chirping second rather frequently.
Old Sep 19, 2007 | 12:30 PM
dkf's Avatar
dkf
Yep change the tranny fluid and fliter regularly.
It is a good idea to take it to a shop that has a machine to ensure all the old fluid is being pulled out of the torque converter.
Just draining the old fluid by dropping the pan will still leave fluid in the torque converter.
Old Sep 19, 2007 | 08:39 PM
rkcarguy's Avatar
rkcarguy
I have removed the tranny cooler line and let the tranny pump out it's own fluid while having a friend add fresh fluid. We kept it running until the fluid coming out cleared up and then shut it down and filled it full. This was on a 1500 suby and it worked well, don't see why it wouldn't work with the ford tranny. Someone correct me if they think it's a bad idea.
Old Sep 19, 2007 | 09:18 PM
ken kenmnedy's Avatar
ken kenmnedy
long as you keep oil in the pump. thats a good shade tree job
Old Sep 21, 2007 | 03:36 AM
rumplefam4's Avatar
rumplefam4
I saw a procedure for this, I think it was on Motorcrafts site. That is how I did it. Mine called for 17.5 quarts but I kept it flushing until I had put in 20 qrts to be sure.
Old Sep 21, 2007 | 05:30 AM
npccpartsman's Avatar
npccpartsman
The only approved transmission fluid for the 5R110 torqshift is Mercon SP. Ford hasn't released the license for manufacture to anyone so it's only available from certain outlets. The pan gasket is reusable and there is an auxillary "toilet paper roll" filter on the right front corner of the truck. Be sure to change that also.
Old Sep 21, 2007 | 06:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
While that's true, this is a 2004 V10 that we are talking about. Those still had the 4R100, which now uses MERCON V.
Old Sep 21, 2007 | 07:02 AM
texasmike74's Avatar
texasmike74
Bearhunter did a write-up on Truck Blog: http://www.truckblog.com/story-582-h...t_transmission
