Best degreaser?
Old Sep 19, 2007 | 08:25 AM
joedellcarter's Avatar
joedellcarter
Best degreaser?
I know this isn't really a 48 and up-specific question, but I'd like to begin the daunting task of removing 59 years worth of grease etc. from my Flathead, and was wondering what degreasers have worked for you. I've used Engine-Brite in the past, but don't care much for the results. Thanks.
Old Sep 19, 2007 | 08:36 AM
Blue50F-1's Avatar
Blue50F-1
A two inch putty knife, a medium flat head screw driver, and then Purple Power.
I've used Purple Power for the last four years in my detailing business. You can pick up various quantities at any parts house. I use it at full strength on engines, soak them down good, let them set a little and then spray them down with a hose. That will cut any film and make your engine look like new, but it isn't very effective on caked on, thick, chunky crud. So, scrape the crap, spray, and rinse. A parts cleaning brush comes in handy for nooks and crannies, too.
James
Old Sep 19, 2007 | 08:37 AM
packrat56's Avatar
packrat56
After a putty knife and/or pallette knife I use plain old paint thinner (mineral spirits) and a stiff brush.
Old Sep 19, 2007 | 08:41 AM
RUSTY50F1's Avatar
RUSTY50F1
I just started the same task. Not a flat head but a rear end. Engine-Brite is a joke. I tried a number of things. A friend told me to use Ez-Off oven cleaner. It worked very well. Just slow. If you have a high pressure washer I'm sure it would work a lot faster. I just used a garden hose, not much pressure but it worked. I used it on the IFS and the IRS Had to do a little scraping on the thick stuff.
Old Sep 19, 2007 | 08:50 AM
joedellcarter
Thanks guys. I use a product called 'Grease Lightning' for my daily driver, but it's a little harsh (especially if you get it on your hands). I'll give purple power a try.
Old Sep 19, 2007 | 09:58 AM
TheWiz427's Avatar
TheWiz427
I've had good results with some stuff i picked up at the dollar store called Awesome cleaner. I use it full strength and for tough spots i let it set for a bit and it usually comes off.
Old Sep 19, 2007 | 12:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
James
This is my method too, an hour of scraping will save a lot of time with the cleaner. Purple Power is NOT easy on your hands, it's very bad for them. I also use a "grout brush" (small stiff brush), they are able to get in tight places and last forever.
Old Sep 19, 2007 | 03:13 PM
Blue50F-1's Avatar
Blue50F-1
No, Purple Power is NOT easy on your hands. As a degreaser it will strip the oils off and out of your hands. It comes in a spray bottle, you use a brush if you have to, and hose it off. If you get it on your hands, it's not the end of the world. Gojo will clean it off, even a good rinse will get it off. I use gloves because of how often I use it (it's great on a rag for upholstery stains etc.), but for the occasional engine compartment degreasing it's no problem.
Old Sep 19, 2007 | 04:33 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've had great luck with Greased Lightning. Its not too easy on your hands though and they might peel after a long exposure to it but it will dang sure take off everything.
I had some brackets that had 30 years of cooked on, caked, on grundge, after a soaking overnight they didn't even have paint left on them.
Bobby
Old Sep 19, 2007 | 05:45 PM
havi's Avatar
havi
I'll have the Roast Duck
Orange-glo from the local grocery store, if all else fails, lol. A hot, hot, HOT pressure washer does wonders.
Old Sep 19, 2007 | 06:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Water straight out of the water heater bottom tap is a great help even just in a bucket.
Old Sep 19, 2007 | 07:08 PM
CharlieLed's Avatar
CharlieLed
Pressure wash first, follow up with Castrol Super Clean full strength, then another good wash. I like the Super Clean (others have imitated, they are all purple in color) and it comes in gallon or sometimes 5 qt jugs at WalMart and other stores. This is a high alkali product (will burn your skin quickly) but it is also a non-petroleum based product and is environment friendly in that it will dillute quickly in water. This is not a fire hazard like petroleum products...really important to some folks who will be moving inside soon to take on their winter projects. This also works well on removing latex paint but it seems to be easy on car paint. It may remove the print from some underhood decals. When I wash my shop towels I dump Super Clean in the washer and let them soak before running the wash cycle, pulls the grease right out of the towels.
Old Sep 19, 2007 | 07:55 PM
DyceDesign's Avatar
DyceDesign
At work we got this stuff that works pretty darn good. Its called "Buggy Blaster" from Trinity...the stuff works great just better have a couple of cans of the stuff.
Old Sep 19, 2007 | 09:21 PM
eman92082's Avatar
eman92082
Scrape and Brush... Lacquer Thinner - Pressure Wash if you can
Dawgie
Old Sep 19, 2007 | 09:48 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Post
Pressure wash then see what is left. Connect the pressure washer to the hottest water the pressure washer can handle. You can buy a a screw in adapter that replaces the small screen many faucets have on the end and hook a garden hose to that. Also get a pressure washer that has a port that you can add cleaner to. You get the best of all options high pressure, hot water and cleaner. You can get a small electric unit for less than $100.00 that will work good for small jobs. I used a small electric unit to clean the floor of my 24 x 36 garage.
