Sponsored by: Real Truck
Transfer case fluid change
Old Sep 19, 2007 | 08:16 AM
rmilchman's Avatar
rmilchman
Getting ready to change the fluid in my transfer case (should have done a logn, long time ago). it calls for mercon and I'm planning on using Mobile 1 synthetic. Is draining and refilling good enough, or should I drain refill, and repeat once?
Thanks
Old Sep 19, 2007 | 09:00 AM
vettdvr's Avatar
vettdvr
Thanks
drain refill is good enough
Old Sep 19, 2007 | 10:03 AM
77hiboyboy's Avatar
77hiboyboy
wow, I have some sort of dark oil in mine. Its sure not mercon. More like 75-90.
Old Sep 19, 2007 | 10:05 AM
GregN's Avatar
GregN
Would anybody here advise against using AMSOIL ATF in the T-Case?
Old Sep 19, 2007 | 03:17 PM
vettdvr's Avatar
vettdvr
I would recommend and I also used
XT-2-QDX, Dextron mercon III Or Mercon V which is a replacement for III.
This should be in the owners manual. If you chose to add something different you might make sure it meets the spec.
<TABLE cellSpacing=0 cellPadding=2 width=643 border=0><TBODY><TR><TD width="20%" height=16>
</TD><TD width="17%" height=16>
</TD><TD width="34%" height=16>
</TD><TD width="30%" height=16>
</TD></TR></TBODY></TABLE>
Old Sep 19, 2007 | 03:23 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Than it's the wrong stuff, as far as I know Unless you're talking about your '77 highboy ... completely different "case" (pun intended).
To the OP: Drain and refill.
Old Sep 19, 2007 | 03:40 PM
xjoedirt55x's Avatar
xjoedirt55x
if it is dirty as heck, or the wrong stuff, i would check and see if there is something that will break down the other stuff, and run it for a little, drain, and re-fill with the right stuff..... that is just what i would do if it was mine, I dont like to take many chances with my trucks
Old Sep 19, 2007 | 05:21 PM
rmilchman's Avatar
rmilchman
The manual says 2 quarts. I would have thought it held more then that, is the manual correct?
Old Sep 19, 2007 | 05:39 PM
vettdvr's Avatar
vettdvr
Yes correct
djed
Jul 31, 2012 12:46 PM
97ExpGuy
35
Jan 1, 2012 01:22 PM
cjg1999
Feb 18, 2008 07:11 PM
oregon250
Mar 2, 2003 08:41 PM
