1978 - 1996 Big Bronco
NO Blinkers
Old Sep 18, 2007 | 07:51 PM
johnarahill's Avatar
johnarahill
NO Blinkers
My 88 doesn't blink. No Green arrows on the dash, nothing. The emergency flashers work, and I replaced the flasher in the fuse box, The Haynes manual says that is the turn signal flasher, but the diagram under my dash says that is the hazard flasher. I don't see another flasher. Anyone know where it is?
Old Sep 19, 2007 | 12:05 AM
mrknight01's Avatar
mrknight01
Ford likes to hide the other one, it is usually right behind the one you see on the back of the fuse block. I would turn on your hazards then pull the flasher and make sure you have the right one.
Old Sep 21, 2007 | 11:06 PM
mrknight01's Avatar
mrknight01
If your flashers are good then it probably is the switch in the column
hdunlap
16
Nov 19, 2016 02:36 PM
jamhh
Aug 20, 2016 08:33 AM
ru67
May 28, 2016 12:21 PM
abe
Oct 3, 2012 08:31 PM
compwrench
1997 - 2003 F150
Jun 25, 2012 04:45 PM
