ive never used spiral frog for my ipod. but i have used limewire. probably the same format. try to bring up i tunes and shrink it down then bring up spiral frog and shrink it down put em side by side. drag the songs from spiral frog to your itunes library then right click the song you will see a convert to acc or aac i forget click on the convert and it should work. works for limewire. good luck
