400 Project
Old Sep 18, 2007 | 06:21 PM
351beast's Avatar
351beast
400 Project
351M went out in my 77 F150 about 6 months ago and i finally got around to building a new engine for it, the old engine has like 350k on it so i decided to go for a salvage yard engine with less miles, there was an old cougar out there that had a 351M with 72k on it, had them take it out and i brought it home and tore it down, project time and i need some opinions
its torn down to the bare block right now, i vated it and painted it, poped in some new freeze plugs and got a 400 crank
Crane makes a cam with .524"/.519" 272°/284° that im pretty sure i want to put in it, but i havent decided for sure, thats the only thing i have really looked at getting for it
where i can get new pistons? im looking to make 10:1 compression and i dont think stock pistons will work
i need some ideas and opinions
Old Sep 18, 2007 | 06:50 PM
havi's Avatar
havi
I'll have the Roast Duck
have you talked to Tim Meyer, this forum's sponsor? He has a piston selection that should get you 10:1
Old Sep 18, 2007 | 08:24 PM
danlee's Avatar
danlee
That is a nice cam and should work well with 10:1 CR.
Old Sep 18, 2007 | 10:51 PM
mustange70's Avatar
mustange70
For the pistons, first decide how much you are willing to spend, as that can determine a lot of what you will end up with in the end.
That said, tim has come out with some new zero deck flat top pistons that will get you in the 9.5:1 range i think, check out his site for the exact numbers, and also the price ain't bad either.
Old Sep 18, 2007 | 11:23 PM
hollenjoe's Avatar
hollenjoe
that cam will take you to 5500 rpm right ? I´ve seen people on this forum say original connecting rods wont stand that kind of rpm, is it true ?
Old Sep 19, 2007 | 09:33 AM
beartracks's Avatar
beartracks
5,500rpm isn't a problem with reworked rods and ARP bolts. It's not easy to get a 400 to turn that fast and still be streetable.
Old Sep 19, 2007 | 10:21 AM
hollenjoe's Avatar
hollenjoe
hmm, so with standard rods its impossibe, why wouldnt they be steatable at 5500 rpm ? on a heavy vehicule maybe but on a light one?
Old Sep 19, 2007 | 10:50 AM
job1bf's Avatar
job1bf
rods are fine...its the rod BOLTS that the real concern.
Old Sep 19, 2007 | 11:13 AM
danlee's Avatar
danlee
The air flow needed for a 400 cu inch motor at 5500 RPM requires a big carb and high flowing manifold. These do not work well at low RPM, so streetability is reduced.
Old Sep 19, 2007 | 11:45 AM
hollenjoe's Avatar
hollenjoe
hmm but tim is olny selling the bolts with the rods, anybody knows where to get the bolts only ?
Old Sep 19, 2007 | 01:19 PM
beartracks's Avatar
beartracks
ARP bolts.
The things that make the 400 a good torque engine tend to work against it for rpm. It'a long stoke, long rod motor with a lot of weight slinging around the crank.
Old Sep 19, 2007 | 05:15 PM
havi's Avatar
havi
IMO, if 5500 rpm is yer aim, I'd go with a Cleveland.
Old Sep 19, 2007 | 07:45 PM
MBDiagMan's Avatar
MBDiagMan
There are some really good responses in this thread.
As said earlier, the 400 is an engine designed for low and midrange torque. Such an engine does NOT make a good high RPM engine. Again, as said before, there is just too much mass slinging around in there to spin at high RPM with reliability.
With something done like heads or pistons to get a good compression ratio, this will make a fun to drive street engine. As when building ANY engine, however, the key is having everything work together. This means that everything should be selected for the same RPM range. In the case of the 400, the only practical RPM range is low and mid. By selecting a dual plane intake(about the only thing available,) a short cam, certainly not to exceed 220 @ .050 at the most, and the 2V heads along with a carb of about 600 CFM, you will have everything working together in the 1,000 or 1,500 up to about 4,500 or 5,000. Trying to spin them much beyond that can be done, but if high RPM horsepower is your desire, you need another, shorter stroke engine as a foundation.
My $0.02,
Old Sep 19, 2007 | 07:50 PM
hollenjoe's Avatar
hollenjoe
I have a 351m , its actually my only choice, and yes i wanna have a fun engine for street use, but i have a light mustang, and I thought of buliding it to revv "high", to 5000 - 6000 rpm, but if you say a 400 wont go that much higher, I dont care having it run to 5000 rpms tops
Old Sep 20, 2007 | 04:12 AM
73XAFalcon's Avatar
73XAFalcon
My $0.02,
I can surely agree with you that the 400 is a good low to midrange motor and it is farely inexpensive to build it for more low-mid range power. However, you can build a reliable 6K - 6500K rpm 400 IF that is what you want. My 400 is built for 6500K. Now, the problem with building a reliable 6500K 400 is COST! You need a forged crank, very high quality rods and pistons, 4V heads, a LOT of cam and a LOT of carb (like danlee said, mine is a Demon 850). Finally, you need a LOT of money. My 408ci motor has over $10K in parts and machining. If I would have paid for labor, it would have cost around $20K to build and I don't even have alloy heads but for the work that went into my 4Vs, I could have bought a good set of CHIs and had a better set of heads.
