unexplained transmission leak
it has had a leaking transmission problem for a while now
156k miles
about 3/4 of a quart a week
replaced the pan gasket with a new factory rubber one
did no good
went and got MoPar dealer ATF RTV
did no good either it stil leaks
but i noticed now that it only leaks at the rear at the crossmember and transmission mount and T case gasket area
what are the odds that its actually a leak from between the case and trans/adaper ?
is such a leak a well known one on these trucks ?
its really aggravating
we are getting rod of the truck soon
trying to fix these things beforehand
it has alot of issues with suspension and brakes and so on
as do alot of these apparently
thanks for anything
but this one is leaking only at the very rear
in the center region
in the middle three rear pan bolts area
at the trany mount width region
and no where else
and its coming from above the pan rail somewhere there
does anyone here know anything to check and how ?? i tried feeling all up around in there and cant actually find anything noticeably wet above the trans mount area
need to figure out something ASAP on this truck
is the transmission case to transfer case adapter gasket known or prone to leakage on these trucks ?
at this mileage and in 97 ?
with borg warner case, the lighter duty auto trans(4r70w?), and the smaller of the two v-8 engines engine
please
thanks!!
if so what does it take to pull the transfer case back in these
i cant see any way to pull it back with this kind of torsion bar crossmember setup that these trucks have incorporated in them
no way to remove any of these parts successfully so the case can come back
OMG ?!
and is there a gasket?
or is it a seal?
or are there one of each ?
really need help badly here
i thought alot of ppl would know about this problem on here with all the mechanics and ford owners that are here
but there arent ?
is there another site where i can find info about this ?
and ASAP ?
thanks!!!!!
we do and have done wayyyy bigger jobs than this in the past, and often,
and have a fully decked out garage and including a big Weaver twin post heavy duty four-arm hydraulic chain vehicle lift, and two stand up pneumatic post style transmission jacks
we have done transfer cases on chevies and older fords but they arent set up like these 97 up fords are underneath, this one looks alot more involved with the design,
the bars look to be pressed into the knuckles and into the part that sits in the crossmember
its crazy...
it doesnt look like anything we would want to get involved with
even with everything we have available both within and outside of our garage
i jut dont see how the case can come back with the torsion bar crossmember where it is,
nothing but about an inch of room between the case and the crossmember, and the top of the case and the cab under floor
thats crazy
i dont understand
if anyone can help on this last thing it would be AWESOME
how to make the room under there to slide the transfer case itself back, by itself
or any other pertinent info in RE of this leak, etc ?
thanks again !!
is there a rubber seal of some sort as well,
or only a flat gasket here, at the front most sealing surface ?
also how long would the output shaft of the transmission be
is it short enough to not even need to worry about pulling the torsion bar crossmember to replace the gasket and/or seal in question?(front most one)
thanks more!
i appreciate
sorry to be frustrated in my above replies
i was really concerned we were going to have to completely tear this truck apart to do this
yeah the exhaust runs across and under the drivetrain yep along with everything else
its crazy
i jut hope the input shaftis realyl short so that the case only needs to come back a couple inches to replace this gasket
hmm
so its only a paper gasket?
wow..
hmm
that has to be whats leaking
cant find anything else that it could be under there
this repair just got pushed back until after we replace the blown up(overheated due to busted radiator)3.0L in the stupid 95 taurus in which we already replaced the AXOD trans in last year,
thanks!!
i appreciate
its crazy
hmm
wow..
hmm
thanks!!
still driving it regardless
this truck needs everything
balljoints, brakes, and so on
its a clean nice loking truck but everything is worn out
at 150k
im not sure what he is going to want to do
he wants to sell/trade the truck in but theres no way he can without repairing/replacing what it needs
dont know
maybe we will still end up pulling the case back in the spring after the snow is gone and fixing whatever, if it really is the gasket or something
he seems ot think it is the vent in the top of the rear of the tranny
but i dont tihnk so
but if it is then thats not a good thing at all
i would think that it means high internal tranny pressures
or maybe not ?
anyone know anything ?
we have a really nice heavy 9,000lb weaver vehicle liff and we have replaced billions of trannies over the years so its not like we cant get it done, but this oen still looks like no fun at all compared to most others
hmm
stupid crossmember and torsion bar design
damn
all i really would need to know at this point is what unbolts first ? the adapter from the tranny, or the trans case from the adapter ?
which way are the bolts threaded and into what, at both ends of the adapter on these trucks ? 470W or whatever tranny
thanks!
happy new year
Rich
yes is a bad leak it is all over the exhaust and crossmember and everything
bad mess lots of leaking
only when driving, not sitting and running
like a quart every few days or less time that sometimes/more fluid
input seal on gm trannies is common yes,
does happen
sometimes they puke the seal, when the trans dies as well
if you could find the info/tsb on this issue that would be great! or a page with the details on what goes wrong and needs replaced exactly
i appreciate the info and help thus far !!!!
rep time !
happy new year
R
