glow plug relay
Old Sep 17, 2007 | 09:50 PM
muddingmcdude's Avatar
muddingmcdude
Question glow plug relay
ok soo my glow plugs are still not workin but i checked 4 of them 2 on both side and they both look good and they check out fine now i got a quesiton is it possible for the relay to get week and not hold the amps it use to and just go right to the relay becuase it thinks that there hot?? because i still have no luck starting it in the morning i gotta hold hte key for about 7 seconds and tons of smoke and when they worked b4 i just taped the key and it started even when it was 0 outside and i know i didnt check the other 8 but there were all new not even 1 year ago about 30,000 miles ago
Old Sep 17, 2007 | 10:20 PM
PLC7.3's Avatar
PLC7.3
What brand were the ones in the engine now......... If they are not Motorcraft/Beru they are probably burnt up already. Azone has MC/Beru for $9 each or less..... these are the ONLY one's to use........
Visit........ http://www.members.shaw.ca/k2pilot/ and read about the other GPs....
Old Sep 18, 2007 | 12:10 AM
tradergem's Avatar
tradergem
Talking autozone glow plugs
Just wanted to let you know if you go to autozon.com and enter zd9 into the search window it will list motorcraft/beru ZD-9 glow plugs for $2.99 each. For some reason if you search using motorcraft or the truck info. only other brands are shown not the ZD-9s that you want. I ordered a set of 8 ZD-9s for my truck on Saturday for $23.92 plus tax and shipping.
Good luck, Jim
Old Sep 18, 2007 | 01:04 AM
David85's Avatar
David85
Did you check for an open circuit in the glow plugs, or did you just do a visual inspection?
Old Sep 18, 2007 | 09:59 AM
muddingmcdude
i just hooiked them up to a battery charger and they glowed red and there not white chalky or ne thing they look good
Old Sep 18, 2007 | 10:00 AM
muddingmcdude
soo IS it posssible that the Relay just is really old because if its the orignal it would have 265000 miles on it
Old Sep 18, 2007 | 10:36 AM
David85's Avatar
David85
I think it is possible, but something else that can happen, is a bad connection at the main engine harness, at least thats the case with the my 86. Might be worth checking all the connections all the way back to the battery before gettning a new controller.
The controller times its operation by risistance in the curcuit, so anything extra will reduce the glow heat.
