Sponsored by: Real Truck
Lift Gearing?
Old Sep 17, 2007 | 07:56 PM
emmagator's Avatar
emmagator
Lift Gearing?
Going with 6" lift, 18" wheels, 37" tires, SCT tuner. Do i need to worry about my gearing on my 2006 F350(not dually)?
Thanks
Old Sep 17, 2007 | 11:36 PM
kbeefy's Avatar
kbeefy
what engine?
Diesels are a bit more forgiving and all the engines will turn the tires, but they'll appreciate gears.
After poking around on big meats, you'll really like the feeling of regearing. I ran 4.88 w/ v-10 and 38's, you might get a little more mileage w/ 4.56's. Powerstroke would probably like some 4.11's.
Old Sep 18, 2007 | 08:11 AM
emmagator's Avatar
emmagator
yea its a 6.0.
Old Sep 18, 2007 | 10:39 AM
TwelveAlpha's Avatar
TwelveAlpha
Ever since I got it I've thought my 456's were just a tad steeper than I like for 35's. Might be just the thing for 37's tho.
Old Sep 18, 2007 | 01:01 PM
DCSpecial's Avatar
DCSpecial
4.56s on a PSD would be for a 38" or 40" tire. I've ran both sizes with my 4.56s.
For a 37" tire I'd do a 4.30
For a 35" tire, I honestly wouldn't even regear unless you tow heavy and then I'd do 4.10s.
Old Sep 18, 2007 | 04:42 PM
pf350's Avatar
pf350
I have 37's and I am going with the 4.56's Just because 1. I tow ALOT 2. I like to jump off the line 3. I drive like an old lady on the freeway 65-70 tops. Should put me around 1850 on the rpms.
Old Sep 19, 2007 | 10:18 AM
mtgrzlyman's Avatar
mtgrzlyman
i have 430s on 37s and my rpms are 2000 at 70mph and she pulls great still in od pulling 12000lbs of toys
Old Sep 19, 2007 | 11:55 AM
pf350's Avatar
pf350
Really, now I have to do some more research. Everything that I have read says that 4.30 would be a touch to high and 4.56 a touch to low. Maybe I should've asked more people what they were running but I was just using the rpm calculator on intercos websight.
Old Sep 19, 2007 | 12:32 PM
mtgrzlyman's Avatar
mtgrzlyman
ive been very happy with the 430s also used the truspeed for the speedo and checked it with a gps and its about as close as a guy can get i think.nice truck bye the way!!!
Old Sep 19, 2007 | 12:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
Here's another way to look at it.
Say you had 33 inch tires and went to 37 inch tires - you have 3.73 gears. You just changed your effective gearing to 3.32. You would need a 4.10 gear ratio JUST to get close to the stock effective ratio.
https://www.ford-trucks.com/calculat.../p-tire_sizes/
Old Sep 19, 2007 | 01:02 PM
DCSpecial's Avatar
DCSpecial
Here's a chart I made that shows how tire size and gear choice effect rpms:
http://www.FTEs diesel forums.com/fo...ead.php?t=2896
Insley95
22
May 30, 2012 11:41 AM
Bluebronco85
1978 - 1996 Big Bronco
Oct 16, 2011 02:51 PM
cjncrckhead17
1997 - 2003 F150
16
Feb 5, 2010 07:42 PM
hatchet
Offroad & 4x4
15
Aug 12, 2007 09:16 AM
dassmoof
Colorado Chapter
Apr 14, 2003 10:56 AM
