Installed 6637 Today
Old Sep 17, 2007 | 07:17 PM
FroggF350's Avatar
FroggF350
I havent really got to test it yet `cause im at work but i get off at 11pm so i`ll see how she does on my way home. Its "only" 55 miles one way so i should get a pretty good feel of it! I`ll post up what i think of when i get home.
Old Sep 17, 2007 | 07:19 PM
F250_'s Avatar
F250_
Congrats, Frogg! Enjoy the new "wooosh"!
Old Sep 17, 2007 | 07:24 PM
Gradymeister's Avatar
Gradymeister
Ya, I love that sound!!
Old Sep 17, 2007 | 08:31 PM
FroggF350's Avatar
FroggF350
drove it around the block one time and never got out of 3rd gear or over 35 mph, didnt really notice any difference, im sure i will when i hit the interstate tonight!
Old Sep 17, 2007 | 09:27 PM
Izzy351's Avatar
Izzy351
Do you have any other mods and/or tuner/chip? Once you get those it will make your turbo really sing!! You might also consider removing the hot-side I/C pipe insulation if you like da' whistle...
Joe
Old Sep 17, 2007 | 11:19 PM
FroggF350's Avatar
FroggF350
yeah i was wondering what the "foil delet" was i will do that in the morning! I noticed a difference on the highway sounds good! so far i have only done open exhaust and 6637, i ordered a d-fuser 18 k but it didnt work so i sent it back my new one should be here next week. I also ordered a whipper whil (Wiked Wheel) should be here wednesday.
Thanks for the info
Old Sep 17, 2007 | 11:25 PM
03Fx4superduty's Avatar
03Fx4superduty
ok im assuming a 6637 is an airfilter from what i gathered. But who makes it? I got a K&N and it blows. I wanna upgrade.
Old Sep 17, 2007 | 11:48 PM
Gradymeister
Thanks for the info
Make sure you get the gasket remover stuff, I used wd-40 and it was a pain in the a$$.
Old Sep 18, 2007 | 12:38 AM
Bird Dog's Avatar
Bird Dog
AKA the kwik mod. 6637 is the part number of a filter that a lot of us here use. Fleetfilter.com or Napa #46637. It requires some modification to your intake system, but well worth it. IMO
Old Sep 18, 2007 | 12:41 AM
bigjake0524's Avatar
bigjake0524
Yes, the 6637 is an air filter. You can get it at fleetfilter.com and you just pull your existing air box out and put the end of the rubber intake hose on the filter. There is pry more info if you do a search for it.
Old Sep 18, 2007 | 05:11 AM
Izzy351's Avatar
Izzy351
Looks like this installed:
You can also see the I/C tube with the foil crap cleaned off. I used Sol-U-Strip from Lowes after peeling it. Took about 90 mins or so for the whole job. Here's the thread I started back when I did mine:
https://www.ford-trucks.com/forums/5...nsulation.html
Joe
Old Sep 18, 2007 | 07:41 AM
RogueSpear2023's Avatar
RogueSpear2023
It also helps to get a 4" long piece of 4" exhaust pipe, put the exhaust pipe in the filter, it will only go in about an inch and half. the attach your intake hose to the other end of the exhaust pipe and use the factory hose clamp to tighten it, some people complain of the intake hose coming off the filter, the exhaust pipe just prevents this.
https://www.ford-trucks.com/forums/542181-this-filters-h-u-g-e.html
22rimfire
6.2L V8
15
Aug 16, 2013 07:09 PM
greywynd
36
May 2, 2010 01:59 AM
Fomoko1
37
Mar 23, 2008 10:46 AM
MAKO314
North Carolina Chapter
May 12, 2007 04:49 PM
mattoney
1983 - 2012 Ranger & B-Series
Sep 9, 2004 10:53 PM
