Yeah, mine has a very small leak too, Vern. Is there a rebuild kit available for them or where could I take it for some other fix? Jim
I just replaced my steerng box.. $119 at Autozone as I recall. 3 bolts and the pitman arm nut.. felt I had too much play in the original one..
The seal kit is $12.
I have the engine out for rebuild as I get the body ready for paint, so it was an easy swap.
That's not an unreasonable price for a rebuilt steering box. Don't have Autozone here but do have VIP Automotive. I'll check there. I may have a new steering box in my future. Mine doesn't have any play to speak of but it leaks just enough to be a PITA.
Do you guys know how to make a positive I.D. on the year/model of "Volare" clip? I'm told mine is from a 79 Cordoba, and I would like to replace all my bushings with Energy Suspension urethane stuff, and don't want to order the wrong kit. I sent E.S. an e-mail, but have not gotten a reply yet. Thanks, Jim
I too would like to know that Jim. After sandblasting the frame i don't see any numbers or markings. Maybe it's a measurement or it's universal parts for several years.
All the Mopar F bodies (Aspen/Volare) are the same. I don't know about the J and M bodies.
I used the M body (87 Chrysler 5th Ave) suspension on my F-3 and I found when checking for parts for it the same parts seemed to fit all the M bodies...not sure about the J bodies though...
Charlie:Horror stories abound concerning bumpsteer, etc.< I have read this from you twice on the R/P subject and wonder where these stories abound from. Where have you read this and can you link it?? I know we talked about Weedeater unit and I wonder if you have contacted them for some input on the issue. I would really like to see more of the negative data as I too see the R/P in my future. I do not want to contact Weedeater unless I have some ammo in reference to the abounding stories which you note.
Jon
Jon
One local 70 year old F100 builder who has installed over 50 Volare IFS's in his day and another owner of a hot rod fabrication shop in TX who has installed a number of Volare IFS's but only attempted a few R&P installs with no luck. The second even said that the Unisteer unit was prone to bumpsteer...I can't confirm or corroborate his claims but it does give me some ammunition when talking to other vendors.
I exchanged a few emails with Dale at Weedetr and he assures me that he has done all the engineering on their product and that there is no bumpsteer. I am leaning towards his product over the much more expensive Unisteer and the self-fabricated unit.
I am waiting on a guy from the HAMB who says that he put a R&P in his 37 Hudson Terraplane that has a Volare IFS and he has over 30K miles on it with no adverse performance. He said that he used a power R&P from a 85 Plymouth and fabricated the mounting himself. He is looking for the pics he took of the job.
Charlie, thanx so much for the follow up. I too have heard a few negatory remarks on the uni version, but it is on the unit made for the tri 5 cars. I did not know they had a unit for the volare ifs. It is a good thing you have talked with Dale, now at least we have some input on record. Now if I could just find some tubular upper control arms for the volare I think it would be a great set up. Thanks again.
Jon
Hey Charlie,a guy told me that polyurethane can have some problems with squeaking, have you had any trouble along that line? I need to rebuild my Volare' as well. I understand poly is supposed to last longer than rubber though. (on the plus side) I don't want to have to do this again in 5-10 years. JNB
I have heard the same thing about urethane bushings. They are harder and more durable (also ride harder), but wear better. However, they squeak. It was recommended to me to use the black urethane that is impregnated with graphite to solve that problem. The graphite makes them self-lubricating. The colored urethanes look cool, but have no lube. I stayed with rubber.
If you have a grease nipple, like Vern, you may be able to keep them lubed enough.
I use Energy Suspension products and only use the black polyurethane...I was told that the black is better because the color additives in the red and green products reduce their effectiveness and increase the probability of squeeks. I lube all the bushings before installation with the lube that the maunfacturer provides in the kit. I believe that it is a good quality silicone product that will stay active for a long time. I see some folks drilling the bushing housings and installing grease zerks...I haven't needed to go to that extreme but I mention it because it is a viable option. The polyurethane bushings not only last longer but they have less give which keeps your suspension tighter for a longer period of time.
