Sponsored by: Auxito
vacuum line connection question
Old Sep 17, 2007 | 03:14 PM
plankofwood64's Avatar
plankofwood64
Where on a 1998 4.2 v6 is the fuel pump regulator control? Is it next to the IMRC on the left, (if you where looking straight at the engine)? I have to connect the red vacuum line to it.
Secondly, the tan colored vacuum line goes to the vacuum modulator valve, correct? Where is the VMV located? I have to connect the vacuum line to it as well.
These are the last two things to connect after an engine swap.
Your response is greatly appreciated.
Thank you.
Old Sep 17, 2007 | 05:00 PM
ncranchero's Avatar
ncranchero
The FPRC is the Fuel Pressure Regulator Control.
VMV is the Vapor Management Valve.
Old Sep 18, 2007 | 04:53 AM
plankofwood64
Wow, Thank you so much!
Do you have the other vacuum connection pictures, (the EGR, EVR, IMRC, etc...) So I can double check my connections?
Thank you.
Old Sep 20, 2007 | 06:26 PM
ncranchero's Avatar
ncranchero
Sorry, haven't been online in a couple of days. Do you still need the other pics if I can get them?
Phantez
Aug 9, 2019 02:17 PM
BigSexy78
Jan 29, 2017 12:19 PM
Nathan J. Hickson
Jan 24, 2017 11:19 AM
Odisvan
Dec 7, 2015 09:15 AM
unioncreek
Feb 3, 2002 11:04 AM
