Rotted Door Frame
Old Sep 17, 2007 | 02:56 PM
Bruker's Avatar
Bruker
Question Rotted Door Frame
What's the best way to repair a rotted door frame? I have a sliding patio door that has a wooden frame that is partially rotted on the exterior. I've removed the rotted wood and I'm left with about a 2.5"w x 5"h x 1.25"thick area where the wood used to be. I'm thinking about using a piece of treated wood approximately the same size as what's missing then filling in the rest with exterior wood filler. What are your thoughts?
Old Sep 17, 2007 | 03:08 PM
Buckarcher's Avatar
Buckarcher
Is this the rough opening or the wood the door track is attached to? Or just the casing?
Old Sep 17, 2007 | 03:28 PM
Bruker's Avatar
Bruker
The rough opening is OK, it's what the lower door track is attached to.
Old Sep 17, 2007 | 03:48 PM
tewferford's Avatar
tewferford
It sounds like it is the lower casing (trim) Remove the entire piece and replace with new. You will spend more trying to repair it.
Old Sep 17, 2007 | 04:17 PM
Buckarcher's Avatar
Buckarcher
+1 That was my thought too, Casing can be bought giving you change for a $20.
Old Sep 17, 2007 | 08:56 PM
Bruker's Avatar
Bruker
Replacing the casing would be the best way to go but this is on a sliding patio door and it's on the section that is stationary.
Old Sep 17, 2007 | 09:26 PM
petes79f150's Avatar
petes79f150
Underneath the threshold?
Pete
Old Sep 17, 2007 | 09:34 PM
Bruker's Avatar
Bruker
Pete
Nope, just the bottom 6" of the casing on the stationary door side.
Old Sep 17, 2007 | 09:58 PM
petes79f150
The JAMB (frame). If so, you've got the easy fix in post #1. Sounds like a sawzall, sharp chisel job to me. "Spackle that sucker".
Pete
Old Sep 18, 2007 | 08:55 AM
fred_79f250's Avatar
fred_79f250
Ya, do it right. Pop the doors out, remove the track, saw out the lower jamb, replace with new, put it back together.
websthes
13
Nov 2, 2009 09:34 PM
z 97ford1
Oct 23, 2005 07:55 PM
