Transmission? Xfer Case? Diff?
New to the forums and I just bought myself a 1990 F150 4.9l automatic 4x4 (push button OD, not sure which one this is yet) and there is an issue with it I can't put my finger on.
When I take off, if feels like something slips out of place and it seems like I lose over half power, when it shifts into second, there is a noise/vibration coming from the back, whatever slipped out goes back into place, and I have full power again. Happens only from 1st to 2nd shift. In 4wd, the same thing happens, only longer vibration/noise.
I'm thinking maybe trans, transfer case, or rear diff (since it's coming from the rear) I haven't taken anything apart yet till I go down to Milwaukee where I have all my tools and such. I'll only be down there for a few days and I'm going to rebuild the trans and rear diff whenI get down there. I just don't want to do both of these and have it be the xfer case. Any ideas?
Definetly change the tranny fluid (WATCH THE PAINT!) and check to see if appears to be burnt or smells burnt. You could change the fluids in the read differential
So now I'm thinking it's a transmission and/or torque converter problem. Explaining the issue better. When I take off slowly these symptoms do not occur. It's only when I take off with a little bit of umph. Getting going, it seems like something slips out of place and there is some power loss. The engine still revs up and I am still gaining speed, just not as fast or with the power I should be. After everything seems to "catch up"/stop slipping/return into place, (this is all in first gear mind you) the trans makes the 1-2 shift. When the shift occurs and there is a rather intense driveline shudder for about 1-3 seconds then stops. Feels like its coming from the bed, which is why I suspected the rear diff, but that has been deemed
I read up a bit on torque converters and transmissions and this seems to explain most of the issues that I am having. Here's what I've found pointing at the TC and Trans...
Slippage- "Another problem that affects the operation of the torque converter is a condition called "transmission drainback." One-way check valves normally keep the torque converter full of fluid when the engine is shut off. But if the transmission input shaft bushings are worn, it can create a path for fluid to drain out of the converter back into the transmission. The loss of fluid from the torque converter can make the transmission feel as if it is slipping on initial take-off for about five to 10 seconds."
Torque converter. Adequately explains the issue I'm having. Happens when I am rolling at 1-10 and from dead stop. Accompanied by a ...
Driveline shudder- "Another driveability problem which may be blamed on the torque converter is a driveline shudder. A shudder may occur if the torque converter lockup clutch has problems engaging, usually because of low apply pressure. In most causes, the low pressure is an internal transmission problem, not a bad torque converter."
Transmission the target here. This is a 100% accurate description of the symptoms I'm having when trans shifts from 1-2.
Terrible gas mileage- "If a vehicle's fuel economy suddenly drops three to four miles per gallon, but the engine seems to be running normally (no misfiring or loss of power), the problem may be a lockup torque converter that isn't locking up. If the torque converter clutch (TCC) fails to engage, the vehicle will still drive normally, but with increased slippage between the engine and transmission. The underlying cause is usually a bad TCC solenoid, but loss of the vehicle speed input signal to the computer may also prevent the computer from energizing the TCC solenoid."
Because the gas mileage on this beast sucks.. harder than it should. Loss of power.. catch phrase there. I'm noticing a loss of power but to TC slippage? Does that count under this?
I'm wondering if anyone else has come across an issue similar to this. I don't want to throw a couple hundered dollars and a weekend at this thing and hope it works better by the "trial and error method" of automobile repair.
Sorry for the lengthy post btw.
My case is the engine seems to 'cut out' or jerk momentarily while there is a load on the engine, such as going up hills towing something. When I turn off the overdrive and the RPM's rise then the symptoms seem to go away.
Does that sound like a torque converter? Thanks for any help.
Mike
Is the CEL on? Have you checked for codes even if its not?
Was the fluid burnt? Has it ever leaked tranny fluid out the front seal (pump seal) but then stops once the truck cools down say over night, but then drips or leaks a steady stream once driven and hot again?
