I'm curious about my 410 and what its torque and HP curves look like?!? In particular, I'm wondering how much using a Performer intake on Performer RPM heads might be holding me back. The ports are definitely a mismatch, but is that a real issue in a hi-boy that will rarely see more than 5K, 5500 max? Would the DeskTop Dyno provide an accurate depiction of this kind of stuff? I hate to waste the $$ on something that won't exactly get used on a daily basis since the die is already cast on most parts.
Thanks. Steve
From other peoples info it has shown to be very close either way. I wouldn't call it optimistic or pessimistic. I have all of the flow numbers for the edel heads and I will post you a graph tomorrow. I am going to bed now. I can't distinguish between the RPM and regular performer but there will be a difference. The ports mismatch but ports being smaller on the intake is much better than smaller on the head.
Thanks Rat!
I don't know what numbers are needed for input for the program, but here is what I've got in case you need them: 410 bored to .040 over, calculated CR 9.9:1, cam is Edelbrock 343941 with matching springs, Sanderson Shorty headers, heads are Edelbrock 6007 427 76CC, carb is Holley 600 cfm on Edelbrock FE 390 manifold.
Thanks again, Steve
Thanks a bunch Rat!!
I take it that there isn't any way to input the two different intakes to see how they would differ? That's a bit of what I was curious about on the software, just how much flexibility it has?!?
Anyway, this will help me with my shift points for sure! I'm headed in with a GearVendors OD unit, and was wondering what RPM range to shoot for. But with that flat torque curve, guess I can't go too far wrong as long as I keep it somewhere on the top side of 2500 or so.
Again, I really appreciate the help!
Steve
