Part Source Help - Alignment Bracket
Old Sep 15, 2007 | 06:37 PM
martydread's Avatar
martydread
Hi All,
Looking for a part, maybe someone can help. Need a fender alignment bracket, the rear one on the firewall, on the passenger side.
I know mid-fifty has some stainless ones that bolt on, but I'd like a plain ol' steel one just like factory that I can weld on. New or used, don't care. No luck in junkyards in my neck of the woods.
Anyone know a source?
Thanks in advance!
Martydread
Old Sep 15, 2007 | 07:08 PM
Brian_B's Avatar
Brian_B
Get a piece of round rod, heat the ends and flatten them, and drill a hole through it. I assume they are round. Truthfully, I never looked. If they are flat..that is even easier.
Old Sep 15, 2007 | 07:30 PM
martydread's Avatar
martydread
Brian_B, thanks for replying, but I have the alignment rods, just missing one bracket off the firewall. Its a formed piece with a number of compund curves, and made of steel, maybe 1/8". It's spot-welded to the firewall and under the cowl on my 56.
I suppose I could make one, but it'd be a whole lot of cutting, welding, and I don't have access to a brake that could handle it. The mid fifty ones look different than the stock ones, they are fomed in a brake and very flat and angular.
I'll keep looking...thanks.
Old Sep 15, 2007 | 07:32 PM
Brian_B's Avatar
Brian_B
Oh sorry. Maybe somone will have one from a junk cab or something. I didn't realize there was a bracket up under there. I have not had mine apart (yet).
Old Sep 15, 2007 | 08:18 PM
AXracer's Avatar
AXracer
Are you talking about the kinda triangular piece that is welded to the firewall under the back edge of the fender that the last bolt on the fender bolts to? If so, I bought a pair of them in plain steel from Mid Fifty just a couple months ago.
Old Sep 15, 2007 | 08:27 PM
martydread's Avatar
martydread
AXracer,
no, there are two firewall-mounted fender alignment brackets, one on each side of the wiper motor, up high and they are spot welded to the firewall and have a tab that is spot welded underneath the cowl.
So I'm looking for for the passenger side mount. PO drilled it out and removed it for some reason.
The fender adjustment rods mount to them and then the rods attach to the front alignment mounts that are on top of the hood latch panel, out on the ends near where the fenders and the hood latch panel meet.
I'll try to take a pic or find a pic of one to post.
Old Sep 15, 2007 | 08:37 PM
Brian_B's Avatar
Brian_B
Now I know what you are talking about. I was thinking under the fenders, not under the hood.
I don't know if you can see them in this pic very well, but you can see the rods:
Old Sep 15, 2007 | 08:42 PM
martydread's Avatar
martydread
Brian_B,
That's them! You can see the driver's side one pretty good in your photo.
I'm thinking I'd just like to buy a repro or a used one before I spend time trying to make one.
Old Sep 16, 2007 | 06:57 PM
raerjim's Avatar
raerjim
I may have one on the old 54 partsmobile, if they are the same. I'll try to remember to check tommorrow.
Old Sep 16, 2007 | 07:08 PM
raerjim's Avatar
raerjim
I just went out with a flashlight and looked, and have both sides. You can have the pass. side or both, if needed. Problem: I don't own a spot weld cutter, and am afraid of boogering them up with a grinder or cutoff wheel. I am not a skilled metalworker, is there some other way of removing them? Jim
Old Sep 16, 2007 | 07:12 PM
Brian_B's Avatar
Brian_B
I have used a center punch and drilled them out before. Usually, I start with a smaller bit and move up.
This site works for the members again. Looks like you will get the "odd" part that you need.
Old Sep 16, 2007 | 08:07 PM
AXracer's Avatar
AXracer
Usually drilling the spotwelds out with a 1/4" bit then popping it loose with a stiff putty knife hammered in between the layers works well. The holes are no problem, give you a place to rosette weld them back on.
I'm probably going to be removing mine and bringing the alignment rods to a new bracket in the center, the OEM driver's side rod will not clear the PB booster.
Old Sep 16, 2007 | 08:46 PM
martydread's Avatar
martydread
raerjim,
I'd gladly paypal you some $$ for your trouble! Or maybe buy you a spotweld cutter! Let me know
Martydread
Old Sep 16, 2007 | 08:50 PM
martydread's Avatar
martydread
Brian_B, you are right, membership certainly has its benefits! I've rec'd more help from members than I could ever imagine.
Old Sep 17, 2007 | 12:12 AM
wmjoe1953's Avatar
wmjoe1953
Wack it with a hammer a couple times, they pop right off. They're not on there very well. A couple smacks, and the pop off with out damaging them. I've popped several off that way, haven't damaged one yet, and it pops the weld with out killing the firewall too.
