Drivers door
Old Sep 15, 2007 | 04:50 PM
i eat hybrids's Avatar
i eat hybrids
Drivers door
Every time i get in and out of the truck i have problems shutting the door. Everytime i try to shut it, it just comes back and doesnt lock tp the latch. I really have to push on it to shut it. I oiled the lock that locks on to the latch on the body and the door worked and shut fine for an hour but then it started acting up again. What do u guys think?
Old Sep 16, 2007 | 01:03 AM
afreemanmd's Avatar
afreemanmd
maybe a little WD-40 or liquid wrench to de-gookify it, and then some teflon spray lube? You said you oiled it, but it might help to de-gunk it with like WD 40 first.
Hope that helps!
Isaac
Old Sep 16, 2007 | 02:35 AM
RACERX7775's Avatar
RACERX7775
this may sound stupid but, check your outside door handle. mine stuck once and the door popped back open after i tried to shut it. i pushed the handle back into position and it latched perfectly.
Old Sep 16, 2007 | 09:19 AM
i eat hybrids
The door handle does stick open. The when u press the key pad, the door lock doesnt lock, but it will lock from the inside. I did oil that and it worked fine for a couple of hours then it stated to act up. Do u guys think i need a new door latch? How hard would they be to change by myself and how much?
Old Sep 17, 2007 | 11:44 PM
i eat hybrids
Bump thread up
Mocha Joe
Jun 26, 2013 08:28 PM
smoke n tires
Oct 13, 2011 05:19 AM
chappys4life
Dec 7, 2009 07:39 AM
red68ranger
Dec 20, 2005 07:52 AM
sbmp1
Apr 15, 2004 12:30 PM
