c8te9425a engine block
Old Sep 15, 2007 | 03:37 PM
65fordguy's Avatar
65fordguy
What Is It?!
Old Sep 15, 2007 | 04:42 PM
fast83's Avatar
fast83
well I can say it was produced in 1968 if it has 8 holes in it it will be a v-8 if the deck is an 8.2 it is a 302 if it is 9.5 then it is a 351 other than that I can not help
Old Sep 15, 2007 | 04:49 PM
65fordguy's Avatar
65fordguy
I am told it is a 360 390
Old Sep 15, 2007 | 05:04 PM
fast83's Avatar
fast83
i would google bore size of both then mic it and you should know at that time
Old Sep 15, 2007 | 06:19 PM
baddad457's Avatar
baddad457
That casting number isn't an engine block casting number, but rather the intake manifold. The block casting number is on the block itself. 9425 is the part number for an intake manifold, block part number is 6015
Old Sep 15, 2007 | 07:38 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep that is one of the "T" intakes. Same as the car "S" intakes except a truck part with the "TE" in the number. Pretty much std issue FE intake. Both T and S were found on cars and trucks. Even tho the T intake has a truck specific number and application they can still be found on cars. And vica versa. Ford was not picky what they used to keep things rollin. There are 2v and 4v versions of each. Just the carb flange is different.
Old Sep 15, 2007 | 08:01 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
And FWIW the 360 and 390 used the exact same block. Block casting numbers are generic for the most part and not much good to ID. You can either measure the stroke with a dowel/wire or remove the oilpan and look at the crank numbers. 3.50" is a 352 or 360 stroke. 3.74 stroke a 390,406 or 427. 3.98 stroke a 410 or 428. Cyl bores you'd really need to measure to be exactly sure. 4.00 is a 352. 4.05 a 360/390/410. 4.13 a 406 or 428. 427 is 4.23. These are all std bore so add for overbore. The same casting number can be found on different bore blocks so they are PMU. Heads, intakes, cranks, rods and almost everything else tho can be ID'd buy the casting numbers. Blocks are the only oddball. If you were certain the engine is original to the vehicle you can see what the engine code was/is. It's also possible it could have always been swapped out with another engine making the engine code useless. But you'd know what engine the vehicle came with from the factory if it mattered.
Old Sep 15, 2007 | 09:45 PM
baddad457's Avatar
baddad457
Originally Posted by FFR428
And FWIW the 360 and 390 used the exact same block. 3.74 stroke a 390,406 or 427..
Amend this to include the 410 having also the same block/bore as the 360/390 and the stroke is 3.78
Old Sep 16, 2007 | 04:17 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
3.784 to be exact. But thanks for the correction. Yep can forget the 410.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
