73 lincoln 460
Old Sep 15, 2007 | 09:58 AM
specialkid66's Avatar
specialkid66
73 lincoln 460
i have a 460 from a lincoln that i want to put in my 2wd 78 f-150. what motor mounts do i have to use?
Old Sep 18, 2007 | 07:39 AM
68murc's Avatar
68murc
You need the factory big block mounts that came in trucks with 460's.
Old Sep 21, 2007 | 02:31 PM
darrin1999's Avatar
darrin1999
or you can buy motor swap mounts. youll also need a rear sump oil pan kit.
Old Sep 21, 2007 | 08:35 PM
greenhighboy's Avatar
greenhighboy
Two wheel drives use a front sump oilpan.
Old Sep 21, 2007 | 09:49 PM
Mil1ion's Avatar
Mil1ion
To the OP.
is you truck a 4x2 or 4x4 ?
4x2's can use the 460 OEM mounts from a truck
4x4's require mounts like that the ones L & L sells
Old Sep 24, 2007 | 10:50 PM
79f150toy's Avatar
79f150toy
I used the brackets from transdapt for the 2wd. Very good product and reasonably priced. My 79 4x4 460 I used motor mounts from a 74 f250 4x4 w/a 360 and used the 400 perches/towers. They are alot cheaper, around 10 bucks each.
Old Sep 25, 2007 | 07:50 PM
79f150toy's Avatar
79f150toy
A front sump oil pan will work on the 2wd, but it will be a pain to remove/install the oil drain plug. But the plug can always be relocated, as that is what I did.
Busted Piston
Dec 18, 2015 08:52 AM
ss27gogeta
May 11, 2014 11:36 PM
fordf100amc
13
Jan 26, 2012 04:31 PM
64Blubyu
Feb 20, 2008 09:03 PM
Ds7776
Sep 26, 2003 12:45 AM
