6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Scientific Study on Regeneration Temps
Old Sep 15, 2007 | 06:20 AM
spatel23's Avatar
spatel23
as I said over at TDG-how many beers did you have?
Old Sep 16, 2007 | 03:54 PM
fordstroker's Avatar
fordstroker
i tried the same thing with a piece of card board and it did not ignite it but it got real close..if it didn't get too hot for me to hold i'm sure i could of held it there long enough for it to ignite...
Old Sep 16, 2007 | 05:20 PM
pdiesel's Avatar
pdiesel
Question
Has anyone stuck a meat thermometer to get a Temp reading. I can honestly say that I cannot tell when my truck goes into Regen mode or I would have tried this.
Old Sep 16, 2007 | 07:40 PM
SUPERDUTY_untouchabl's Avatar
Maybe you should just lift your truck. Hay next time throw some steaks on it next time and see ow long it takes to cook it.
Old Sep 16, 2007 | 08:03 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
I'd have to lift my truck 3 feet to get it outa the grass.
Old Sep 17, 2007 | 12:18 PM
Tornitron's Avatar
Tornitron
Other than the potential risk of starting a fire, I wonder what the long term effects of these high temperature regen cycles will do to the underside of the truck.
Old Sep 17, 2007 | 04:07 PM
Buckarcher's Avatar
Buckarcher
A client of mine just did some remodel work at a shop where they train techs to work on the cummins (I think he said cummins anyway) engines. They installed a fan system to remove exhaust from the room when the engines are running. He specifically ordered a fan that could handle some heat but Broan sent him a fan with plastic fins. Well even 30 feet up at the ceiling the temp was hot enough to melt the plastic fins right onto the rotor and seize the fan up. He said the tech told him they are at about 1500F at the exhaust tip.
That's all second hand info so take it with a grain of salt, but I don't think a meat thermometer is going to help you much there.
Old Sep 17, 2007 | 05:21 PM
97squarebody's Avatar
97squarebody
Hello all;
You do not want a meat thermometer, you want a candy thermometer. I use one for frying, its good to around 550 or 600 degrees. (What can I say I like to cook. Actually I prefer the eating part, but you know how that goes.) The other option would buying a new toy and going contactless infared temp guns.
Old Sep 17, 2007 | 05:40 PM
Buckarcher's Avatar
Buckarcher
Originally Posted by 97squarebody
Hello all;
Actually your local fire department might have one and they always like to play. If you get the right guy they might pull it out and check it for you.
Old Sep 17, 2007 | 08:59 PM
F350-6's Avatar
F350-6
The fire department is a good idea, or if anyone is around Dallas I have an infrared that goes up to about 1000 deg.
Old Sep 17, 2007 | 09:50 PM
fordstroker
i have a digital heat gun we use for racing i'm sure that will work..if i can catch it next time i'll check it..
