Spongy brakes
Old Sep 15, 2007 | 02:29 AM
paul812's Avatar
paul812
Spongy brakes
does anyone notice there brake pedal being spongy? My '05 scab is horrible, at idle, in park, i can press the pedal within 2-3 in. of the floor. Theres been a few times when i really didnt know if i was going to get stopped in time, in an almost emergency type situation. There should not be any air in the system. And theres no pulling to one side.,,,or any dash ABS lites on. I sure wish it was like my wives 2000 grand marquis,,,very little "softness", it will stop on a dime. I know the truck is heavier, but still the pedal should NOT be that soft. Any comments?? thanks paul
Old Sep 15, 2007 | 08:21 AM
DaMole's Avatar
DaMole
What year and how many miles?
Old Sep 15, 2007 | 08:42 AM
black04lariat's Avatar
black04lariat
Have you checked your brake fluid level?
Old Sep 15, 2007 | 08:50 AM
gui88ford's Avatar
gui88ford
my break pedal is spongy expecially when compared to my 01 i had...it's not very bad but it's a spot that i wish was better...
Old Sep 15, 2007 | 05:34 PM
soxfan81's Avatar
soxfan81
bleed your brakes. When I changed the pads I bleed the brakes and they were alot better I barely have to press the pedal.
Old Sep 15, 2007 | 08:36 PM
paul812's Avatar
paul812
its a '05 scab w/4.6 and 14k miles. fluid level o.k. been like this since new., well maybe seems like its getting worse. do you think it could have some air in the lines from the factory??? wouldnt that cause the differential valve to throw a light? soxfan...were yours spongy before you bleed them? i might try the rear first,, cause if the front had air , it should pull a little to one side when braking. thanks...paul
Old Sep 15, 2007 | 09:01 PM
soxfan81's Avatar
soxfan81
My brakes weren't spongy the pedal had more travel than it does now. I like the feel of the brakes now compared to when I bought the truck. I have read posts of people have spongy brakes from the factory and they bleed the brakes and it fixed the problem.
Kuhns71
18
Aug 22, 2016 12:22 AM
ericjacobsen3
13
Aug 29, 2014 02:18 PM
88idigray
Mar 18, 2014 11:04 AM
A/Ox4
Mar 17, 2014 10:46 AM
DieselDowdy
Jul 9, 2013 06:28 PM
