Spongy Breaks
Old Mar 17, 2014 | 04:15 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Spongy Breaks
Today I replaced my front calipers. I expected the pedal to be soft after, but I've driven quite a few miles now. How long will this go on? It has gotten better, and its driveable, just not 100%.
If I jab the brakes it pulls HARD left, so I know that one has started working. Will fluid eventually make its way to the passenger side?
Old Mar 17, 2014 | 05:45 AM
mueckster's Avatar
mueckster
Did you just gravity bleed, or did you also pressure bleed them? Do you have 4 wheel ABS? You could have some air there that needs to work out.
Old Mar 17, 2014 | 06:02 AM
Walleye Hunter's Avatar
Walleye Hunter
Pedal should never be soft after and it's a condition that does not remedy itself. You will need to bleed your brakes. I have had great success just gravity bleeding mine if I keep the fluid from draining out of the lines when I do the job. And it works best if you loosen the cap on the master cylinder.
Old Mar 17, 2014 | 10:46 AM
timmyboy76's Avatar
timmyboy76
Spooner...you bleed in correct order.....r.r., l.r., r.f, l.f ?
Jimmyfoxx
Mar 23, 2016 09:19 PM
jebby69
Jun 3, 2010 04:01 PM
Talyn
Sep 29, 2009 10:08 PM
74fordtruck
13
Sep 25, 2005 11:39 AM
1rezman
Apr 15, 2002 08:25 AM
