Front Bearings
Old Sep 14, 2007 | 08:19 PM
Beachx's Avatar
Beachx
Front Bearings
Hello, I have been watching the forum for a few weeks now and have come to the conclusion that if you cant find the answer here it ain't broke.
With that being said, I am having the time of my life with my front bearing assemblies. I have a 2000 X 4x4 V10 135,000 miles and in the past year 25,000 miles have had to replace each front side of my bearing twice. I am getting the grinding sound, where it comes and goes with a bump in the road and then hit another bump and it goes away. Once this starts I have replaced the bearing assembly. Luckily after buying two they are under warranty and it has not hit the pocket book as bad. The tires wear fine, and the truck tracks, and brakes great. I was hoping someone has a fix for me? It is getting old tearing down the front to replace these bearing every 6-8 months. The needle bearing always look ok, it is the assembly itself that appears to be failing.
Any ideas would be greatly appreciated. I have no plans on getting rid of her any time soon, I just put a new engine in her from Ford this past winter. (I had a rod bearing go out.) Apparently whoever had it before me did not take good care of it.
Thanks
Brian
Old Sep 15, 2007 | 09:07 AM
DetailerDave's Avatar
DetailerDave
Where are you buying the hubs from? Do you have different wheels than stock?
Old Sep 15, 2007 | 06:16 PM
Beachx's Avatar
Beachx
The first came from Pepboys the second set came from advance auto. The tires rims are stock size, just load rated on the tires.
Old Sep 15, 2007 | 06:55 PM
K9BELLA's Avatar
K9BELLA
Are you sure you did not over tighten the hub?
Old Sep 15, 2007 | 07:06 PM
Beachx's Avatar
Beachx
Are you asking about the 4 studs that hold the hub? They should not have been to tight. But I did not torque them.
housedad
Sep 18, 2011 11:52 PM
ak49er
Apr 27, 2011 07:02 PM
Johnny Bravo 45
Aug 3, 2010 09:35 PM
tws1616
16
Apr 12, 2010 04:25 PM
Ford43
Escape & Escape Hybrid
Nov 24, 2007 03:38 PM
