I did a comp test which went like this on a stock 390 2bll
passenger side front to back,125,125,85,120.drivers side
125,125,110,115, I think thats the order,whats the
actual compression cause my buddys car gets 165's and
his car runs 8.6 to 1, I have 8.5 to 1 so they should be
bout the same right? How much compresion can I lose before
needing to rebuild it? It still does the 1/4 mile in 16 seoconds
flat
I'm not shure on exact spec's, but with that 85 in there you should check out the problem. I was down to 48lbs in #6 cyl. and found that I had sucked a valva about 1/8in into the head. I still had great get-up-n-go just a really bad miss. Not sure if I'm actually helping you but just thougt I'd let you know. Good luck.
