another cam question
Old Aug 11, 2002 | 06:03 PM
Alz Ryde's Avatar
Alz Ryde
Hi guys,new guy on the block here,so be nice.When going with flat top pistons at rebuild time,I'm considering an Isky cam with the following-.214@.050,.525" 108LC.The motor is a 390,4BBL w/Performer man,dual Flowmasters w/stock ex man,very little stop and go driving,mainly pull out of the driveway and up to speed (26-2800 rpm).Could someone with desktop dyno run some #'s? The heads are C1AE's w/stock size valves,the truck has 4spd w/3.92 gears,33"tires.Would this be a good cam choice considering cruise rpm range/comp ratio w/flattops?many thanks in advance,Al ps-the motor at present has Isky 256/262 with what I believe to be 410 pistons due to how they sit a little low in the bores.
Old Aug 12, 2002 | 02:06 AM
Scotty1's Avatar
Scotty1
