transfer case
Old Sep 14, 2007 | 01:42 AM
big show's Avatar
big show
transfer case
i have a problem with my transfer case i have a 77 f-250 with a NP205 the truck will not move even when i lock in the front wheels. sometimes when i rev up the engine while in drive it will move about 10 ft and then slip back out into nuetral any help would be appriciated
Old Sep 14, 2007 | 02:34 AM
greythorn3's Avatar
greythorn3
Throw away society!
throw it away and buy a new one. at least thats what 90% of americans would do!
Ray
Old Sep 14, 2007 | 06:51 PM
evam350's Avatar
evam350
Sounds more like a trans issue to me, is it auto or manual?
Did this problem just arise out of nowhere or were you working on the truck prior to this happening??
Old Sep 14, 2007 | 07:32 PM
greythorn3's Avatar
greythorn3
to me it sounds like somone has low trans fluid.
Ray
Old Sep 14, 2007 | 07:40 PM
m78's Avatar
m78
clutches slipping
Old Sep 14, 2007 | 09:10 PM
Matts72's Avatar
Matts72
The only way that an NP205 won't work is if it is blown apart. Check the tranny fluid or clutch engagement.
Old Sep 14, 2007 | 10:07 PM
big show's Avatar
big show
it is a C-6 and it just happened i will check the fluid level
thank you
Old Sep 16, 2007 | 10:58 PM
big show's Avatar
big show
I Found The Problem I Have A Leak In The Hose Comming From The Transmision Cooler And Was Low On Fluid Problem Is Now Fixed
Thans For All Your Help
