Super LOUD after injector pump install??
Old Sep 14, 2007 | 01:22 AM
sixtyfive_ford's Avatar
sixtyfive_ford
I've been having trouble with rough running at start up and hard starting so I finally got around to replacing the injector pump. Now the 6.9l starts very easy and has more power. The only thing is that it is 5 times louder and seams to use alot more fuel. Before the install it ran nice and quite now I can't hear myself think. It isn't the exhaust it is coming from under the hood. What do I do???????
Old Sep 14, 2007 | 08:23 AM
PLC7.3's Avatar
PLC7.3
Did you have the engine timed after installation of the new IP............sounds like too far advanced.
Old Sep 14, 2007 | 11:06 AM
sixtyfive_ford
I did not. I know virtually everything about gas engines but I feel like I am learning for the first time about deisels. I am assuming I need to adjust/rotate the injector pump to time it?
Old Sep 14, 2007 | 02:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Yes that is how the timing is set.
But first, how was the original IP removed?
Was the IP removed from the timing gear cover or was the cover and gear removed with the IP?
Old Sep 14, 2007 | 03:03 PM
sixtyfive_ford
The IP was removed from the timing gear. The timing gear was left untouched.
McQ
15
Jun 17, 2012 08:33 AM
mudkicker715
18
May 18, 2009 09:33 PM
RLord4268
Oct 3, 2005 11:14 PM
hayfrmr318
Oct 14, 2004 05:24 AM
DieselMan04
Aug 1, 2003 07:21 PM
