How to check wheel alignment?
Old Sep 13, 2007 | 11:38 PM
kevin.ford-trucks's Avatar
kevin.ford-trucks
Is there some way to roughly check the front wheel alignment? A four wheel alignment? I'm just very sceptical of the "shops"
Old Sep 14, 2007 | 01:42 AM
Monsta's Avatar
Monsta
Sit. Stay.
Look at the tire wear. Make sure it tracks straight when your hands are off the wheel.
Both ways will give you a "rough check".
Old Sep 14, 2007 | 06:07 PM
igotoneforya's Avatar
igotoneforya
A rough alignment check is a tape measure. Measure front of front tires as well as back of front tires, this means the distance between both front tires using leading and trailing edges. Theses edges are a minimum of 30 inches apart. SHould be the same. You need to use the same lug or line on the tire to ensure as much accuracy as you can. This works well on true 4WD vehicles where close is good enough. It is only a rough estimate on street vehicles but with some tires (with good lines) can be pretty accurate, mud/rock tires have changing lugs that makes this difficult.
