"pinned steering column"
Old Sep 13, 2007 | 11:01 PM
trackenator's Avatar
trackenator
Hey all got a quick question. I have a 1990 f150 4x4 auto 5.8 e4od . 4.5 suspension lift and 35 in tires. I have a performance accesseories 3in body lift to put on and it says i do not need to weld anything into the steering shaft just check the steering column and see if its "pinned" together. if it is just drill it out and it will extend. do they mean the shaft under the hood? i thought the column was inside the cab. and if it is under the hood is it the end closer to the gear box that moves? thankx all.
