SD to MAF????
Old Sep 13, 2007 | 04:58 PM
wayneF250's Avatar
wayneF250
SD to MAF????
what year mustang is needed for a maf swap. on a 94 F250 5.8 , the way I see it I need the intake, wiring harness , and EEC , w/ all the sensors.Will the truck injectors work in the mustang intake??and what extra sensors will i need from the mustang??
Old Sep 13, 2007 | 05:36 PM
EPNCSU2006's Avatar
EPNCSU2006
You don't necessarily need the mustang intake manifold, unless you just want to use it. The injectors are the same between the truck and the mustang, so no worries there. If you haven't seen this site: http://bjoern.brembs.net/cars/maf_conversion/ take a look and read through what's necessary when using the mustang computer and mass air system. Every sensor on the truck can be re-used, you just have to add the mass air meter and its wiring, along with wiring to each injector since the mustang is sequential injection. 89-93 mustangs are the most common ones used for maf swaps.
