intearior 1981 F-150
I made mine out of TransAm seats. I flipped the bench over and welded square tubing between the 2 bracket assemblies, then removed the seat from the brackets. Take the brackets off of the donor seats, set them on your "frame" to see where you need to weld in for the inside bolts of the donor seats. I put a bronco console in between and it was pretty sweet. I have since put a bench back in it, since I now have kids. I'd probly give it to you if you were closer. Seats aren't it too hot of condition, but the console and frame is all still there. Gathering dust in the shed.
