drive shaft
Old Sep 12, 2007 | 11:55 PM
bob_351's Avatar
bob_351
drive shaft
When I give my truck gas I get a little clunk and sometimes when I let off it clunks again. I suspect the u-joints are to blame, what do you guys think? What needs to be replaced and how hard is it?
thanks
Old Sep 13, 2007 | 01:23 AM
jimbo beam's Avatar
jimbo beam
I just did u-joints in my 86, to cure the symptoms you described. It was no big deal, 4 bolts to unloosen on the rear end, and slide the front slip yoke out of the tranny, took a whole 5 minutes to remove the shaft from the truck.
Removing the u-joints from the shaft was a pain, I ended up using a crappy socket as a press, I put the drive shaft in my vice and used the socket to push the u-joint out of one side. I removed the cap from the now free side, and i pressed out the other side. before I forget there are snap rings that hold the u-joints in, they're easily removed with a small pick and a flat bladed screwdriver
Installing the new u-joint was as simply as reversing the removal process, I pushed one side of the u-joint in by hand, and installed the new snap ring. I had to use my "press" to push the other side in far enough so the snap ring would seat in the grove.
The new u-joints should come with grease in them, but it never hurts to add more. I reinstalled my drive shaft and greased the new u-joints until the grease spewed out of them.
Old Sep 13, 2007 | 05:51 AM
jinserra's Avatar
jinserra
I agree with Jimbo... thats the way that I do them when I have to.
Old Sep 13, 2007 | 07:47 AM
srercrcr's Avatar
srercrcr
I put in new joints with zerk fittings so i could always keep them lubed. I have one though that the grease gun won't fit onto the fitting, I have the joint flipped around the wrong way. I'll just leave it until it goes out in 2027.
Old Sep 13, 2007 | 06:23 PM
Franklin2's Avatar
Franklin2
Just a little tidbit of info. The offroad guys don't like the u-joints with grease fittings. The grease passageways make them weak. I would personally prefer them myself, and I got one at Napa before that was some super-duper u-joint that had the grease fitting on the outside of one of the bearing cups.
