late shift ????
Old Sep 13, 2007 | 11:31 AM
tony mathers's Avatar
tony mathers
late shift ????
My 95 psd. is slowly getting layter in it's shifts. The trans. is shifting up around 2,200 rpm's to 2,500 rpms. Evan if I take off real slow."kinda like my grandma going to bingo". I cleaned the rear-end sensor on top of differential to see if it was the problem. It was real clean and did not change anything. Can any-one help with this problem????
thanks TONY
CDL instructor
Old Sep 14, 2007 | 12:00 AM
c00nhunterjoe's Avatar
c00nhunterjoe
truck may be low on power and you are giving more throttle to compensate, you'd be surprised how little throttle it takes to raise the shift points, if its definatly not that then i'm not sure what els would cause it. it goes off a predetermined route in the pcm, she's electronic inside
