Towing w/ 4-6" Lifted Excursion
Old Sep 13, 2007 | 09:44 AM
Mugenlude's Avatar
Mugenlude
How many people are towing with their lifted Excursions? I'm not talking about just some little trailer, I'm talking at least 5000 lbs. Are you using a weight distribution hitch?
I know that the stock suspension has been known to wander as it goes down the road, and changing out the rear springs helps with this. My brain tells me that if I raise the center of gravity it is going to tow worse than before, however, maybe the 'lift' springs are stiffer than the stock ones and it isn't an issue.
I have a drop shank with my current WD hitch that is pretty low, but I don't know if it would accomidate a lifted Excursion. My Jeep GC's receiver is pretty high, and my current car trailer is low.
My first concern is the drivability, second is if my WD hitch will work due to the height. I will be purchasing a 2WD model, so I will gain a couple inches that way.
Old Sep 13, 2007 | 09:46 AM
i eat hybrids's Avatar
i eat hybrids
is urs a lifted 4x4 or 4x2?
Old Sep 13, 2007 | 09:56 AM
jake00's Avatar
jake00
I pull a 9000lb equip trailer with my lifted SD. but the trip is less than 20 miles
Old Sep 13, 2007 | 10:04 AM
Mugenlude's Avatar
Mugenlude
Mine (when I buy one) will be a 2WD model. The one I'm looking at is lifted, so I want to see if it's worth it or not.
Old Sep 13, 2007 | 11:04 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
There is a memeber I know of Aatcntrl1 that tows with a lifted Ex as there are many others as well...you may want to PM him to see if he has any insights for you...
When you look at lifted Ex's...take a gander at the load range on the tires...make sure they are E's if possible...the E's can be aired up to 80psi and makes for a more stable tow experience. Some larger diameter D's though carry just as much load (i.e. #'s per tire) as a 265/75R/15 E stock tire though...side wall flex is what you want to AVOID.
Reese and the other WD hitch mfgs make all kinds of drop shanks...you may want to call your WD hitch mfg first though to make sure their WD system works with lifted trucks...or better yet ask them if there is any lift limitation with their hitch head and spring bars...just a thought...
Good luck!
joe.
Old Sep 13, 2007 | 11:20 AM
i eat hybrids
I tow 6000 pounds
Old Sep 13, 2007 | 11:25 AM
Mugenlude's Avatar
Mugenlude
Do you have any photos of your hitch and trailer setup? Could you get me the measurement from the bottom of your receiver opening to the ground?
Originally Posted by i eat hybrids
I tow 6000 pounds
Old Sep 13, 2007 | 11:41 AM
i eat hybrids
No i dont have any pics. The boat is in rack storage and the trailer is stored. We only tow it like 4 times a year. If u have any ques ask
Old Sep 13, 2007 | 04:41 PM
i eat hybrids
http://www.hotboat.com/forums/showt...&highlight=rigs
Hope this helps. They may not be 2wd but it is a ton of jackd up trucks towin.
Old Sep 13, 2007 | 05:37 PM
sturzinator's Avatar
sturzinator
I also regularly tow 5-6k. Boat in the summer, and enclosed snowmobile trailer in winter. Zero problems.
Old Sep 13, 2007 | 06:05 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I tow 13,000 lb with my X but it is not lifted. Why dont you want 4X4. We hardly use it but there have been 3 times that if we didnt have it we would have been up a creek with out a paddle. Just tossing the idea around,
Nick
Old Sep 13, 2007 | 06:41 PM
7.3 4X4's Avatar
7.3 4X4
My Ex is not lifted, but it has LT275/65R20 tires. It pulls my 7500 lb. camper with no problems whatsoever. My WD hitch has a height adjustment. When I purchased the truck, I simply adjusted the hitch and have had no problems.
Old Sep 14, 2007 | 08:19 AM
Mugenlude's Avatar
Mugenlude
i eat hybrids - Thanks for the link, we'll it's broke, but I used the search function on the site. =)
sturzinator - what kind of WD hitch are you using? I have a pretty low shank drop on my Jeep GC right now (~6"), but I have seen some 8" drops for sale online.
weekendwarriorfsw32 - At one point I was thinking of a 4x4, however, this will be my race car hauler, and we don't race in the winter. So the couple times that I might want it don't out weight the maintenance or additional purchase price.
7.3 4x4 - Thanks for the info...
Thanks for all of the replies guys, but unfortunately the X sold on me... so I'm still on the lookout. =(
Old Sep 14, 2007 | 08:28 AM
i eat hybrids
Did u find the tow rigs?
Old Sep 14, 2007 | 09:04 AM
Mugenlude's Avatar
Mugenlude
Yeah I found the forum... Thanks.
