tire size question
Old Sep 12, 2007 | 10:43 PM
goodwrench's Avatar
goodwrench
tire size question
I noticed my 99 2wd four cylinder automatic is suppose to have 225/70-15. It has 205/70-15. What i was wondering was how much is the speedo goin to be off? And say over 200 miles on the odometer, how many miles is it going to be off?? I figure it couldnt be more than a couple?? anybody know??
later chris!!
Old Sep 15, 2007 | 09:33 PM
rubydist's Avatar
rubydist
Visit tirerack.com - they will give you specs on the tires diameters, and you can calculate the ratio of the current size to the correct size to see how much difference there is. Then, take into account that generally Ford sets up the speedometer to read 2-4 mph higher than actual, since people tend to want to drive slightly over the speed limit...
Old Sep 15, 2007 | 09:42 PM
ranger1999 Bob's Avatar
ranger1999 Bob
actually youre suppoused to have 215 70 r 15 if memory serves correct... ive upgraded to p225-75R15 cause i do alot of heavy hauling and would like more tire on the road
Old Sep 16, 2007 | 06:54 AM
wendell borror's Avatar
wendell borror
It wouldn't be enough to worry about.
Old Sep 17, 2007 | 03:46 PM
MF11283's Avatar
MF11283
if your speedo is 100% accurate (which its not) at 60 MPH by the speedo youd be traveling 57.6 MPH. so whats what like 4 or 4.5% off so like 191 or 192 miles when your odometer reads 200
Old Sep 19, 2007 | 09:27 AM
beater ranger91's Avatar
beater ranger91
mf11283 is right but just for future referance i'll give you the formula
to figure this out you must know the tire diameter in inches
tire diameter=2x sectionwidth x aspect ratio +rim
2540 dia. (this is a constant)
once you have tire diamter in inches for both old and new tire plug the numbers into this formula.
actual speed= new tire diameter
old tire diameter x speedo guage reading.
