Thermactor ports
Old Sep 12, 2007 | 05:53 PM
rjvaughan's Avatar
rjvaughan
Thermactor ports
Hi,
What do folk usually do with the thermactor ports in the back of the heads (assuming they get rid of the thermactor system)?
I was thinking they could be tapped and a bolt screwed in?
I've got a '79 460.
Thanks in advance for the advice.
Rob.
Old Sep 12, 2007 | 07:34 PM
79superduty's Avatar
79superduty
could do that or a steel or brass soft plug.
Old Sep 13, 2007 | 11:16 AM
mcdonaldm's Avatar
mcdonaldm
i tapped my heads and installed a SS plug into them. the port is actually a stepped hole, that is there is a larger outer hole and smaller inner hole. the inner hole is sized perfectly for i think it was a 1/4" npt tap and plug. just put a lot of grease on the tap so no shavings get inside the head and into the engien.
they do make plugs to fit these holes as they are a weird size, but the tap method was easy to do.
rgds
Mike
Old Sep 13, 2007 | 11:40 AM
rjvaughan's Avatar
rjvaughan
Thanks for the info Mike, does SS mean stainless steel in this case? I would be doing this with the heads off before they were cleaned and re-built.
Old Sep 16, 2007 | 10:56 PM
fasthauler's Avatar
fasthauler
It wouldn't make any difference if the were stainless steel or not. They are never going to come out again, so it doesn't make any difference if the corrode or not.
Old Sep 17, 2007 | 11:53 AM
mcdonaldm's Avatar
mcdonaldm
you don't have to use stainless steel plugs, that is juast what i had on hand. plain steel will work also.
rgds
Mike
Old Sep 18, 2007 | 07:59 AM
68murc's Avatar
68murc
I just used some small core plugs. I smeared some of that exhaust cement on them before tapping them in. It's been over a year now, and no leaks.
BigBlocker0248
Jan 20, 2016 06:41 PM
Ed Bamba
Jan 27, 2015 09:21 PM
Broncofever89
1978 - 1996 Big Bronco
Jul 16, 2014 03:24 PM
FEmtnmax
Aug 27, 2003 08:38 PM
JoeBlow
May 15, 2003 12:00 AM
