I have been looking for a 351w roller motor perferably, but is starting to be impossible for a reasonable price, so I've been thinking of buying a hydruallic flat tappet 351w and converting it to roller. I know you have to convert with screw in stude for roller rockers but is there anything that needs to be done to the block for the cam itself or can i just put a roller cam into the block as it is?
all you need to do is get the rollor cam you want and some H-link rollor lifters. You will also need the right length pushrods, stock heads are fine no need for adjustable rockers unless you are going with solids.....
