truck wont start
Old Jul 21, 2007 | 12:51 PM
slenherr's Avatar
slenherr
truck wont start
have a 2005 f450 6.0 auto and sometimes when you go to start it it wont do anything. where the odometer is it says check gauges thanks
Old Jul 21, 2007 | 06:09 PM
ReAX's Avatar
ReAX
You need provide us with alot more information if anyone is going to be able to help you. Does the starter click, do the lights dim when you turn the key to start, does the wait for start light shine, does it start up normally when it does start?
Old Jul 21, 2007 | 09:34 PM
slenherr's Avatar
slenherr
when it does it the starter does not click the lights dont dim. when it wont start the wait to start light stays on and a wrench pops up in the display and check gauges pops up where the odometer is.when it does start it starts and runs fine thanks
Old Jul 22, 2007 | 03:27 AM
ryaneverk2's Avatar
ryaneverk2
Moved to 6.0L PSD section.
Old Jul 23, 2007 | 02:04 PM
slenherr's Avatar
slenherr
any body have any ideas
Old Jul 23, 2007 | 02:53 PM
tttario's Avatar
tttario
Do you have keyless entry? It happens to me sometimes, all I have to do is press the unlock button on the remote twice and it allows me to start. Normally happens when I lock from the remote and unlock from the keyless entry. I think it is a security thing.
Old Jul 23, 2007 | 04:00 PM
toolman05kr's Avatar
toolman05kr
do you have an aftermarket alarm or remote start? if so it could be a bad start interupt relay in the alarm circuit. Also check the starter relay as they are known to go bad.
Old Jul 23, 2007 | 08:50 PM
slenherr's Avatar
slenherr
no dont have keyless entry its a stripped down xl. no aftermarket alarms,is there any way to check the starter relay. also got codes read today and got a p0266 code.
Old Jul 23, 2007 | 09:38 PM
blackhat620's Avatar
blackhat620
P0266= Cylinder #2 contribution/balance
When maximum/minimum pulse width adder is exceeded and cylinder does not converge a fault is set.
Without further diagnostics by a competent & certified 6.0 tech it will be hard to determine what is causing this problem.
Old Jul 24, 2007 | 10:33 AM
Reave1's Avatar
Reave1
Somthing electrical is going on it seems. possibly the starter selenoid? or the starter itself? could be shorting things out.
Last edited by Reave1; Jul 24, 2007 at 10:35 AM. Reason: did not apply like I thought
Old Jul 24, 2007 | 05:03 PM
slenherr's Avatar
slenherr
where is the starter selenoid located at. would the 100,000 mile warrenty on the motor cover the electrical problem. truck only has 42500 mile
Old Jul 24, 2007 | 05:31 PM
npccpartsman's Avatar
npccpartsman
There is an electrical schematic in the 6.0 bible in the tech section. Starter solenoid is on the starter. Starter relay maybe? Have you by chance checked all the fuses? There was a certain production run of trucks that had the fuses incorrectly installed in the fuse box where the blades didn't actually get into the spade terminals. Electrical is hard, but it sounds like something in the starting circuit where a relay isn't kicking all the juice to the starter.
Old Jul 24, 2007 | 08:21 PM
Beerstalker's Avatar
Beerstalker
npc, is the link for the 6.0L bible still there, cause I'm not seeing it?
Old Jul 24, 2007 | 08:33 PM
blackhat620
It's in the 6.0 Tech folder, 5th topic down from the top
http://www.ford-trucks.com/forums/30...ch-folder.html
Old Jul 24, 2007 | 08:51 PM
Beerstalker
So I'm only half blind. I was looking for 6.0L bible in big lettering, not as part of the link. It's acutally the 6.0L Technical Intro Manual.
