Odd Tire Question:
The one he ordered:
$140
Goodyear Wrangler Silent Armor
LT265/70R-17/C1 112R (31636)
http://www.discounttire.com/dtcs/fin...d=008443&ar=70
And the one I was expecting:
$175
P265/70R-17 113T OWL (31624)
I understand he ordered the lt(Lighttruck), but why would the LT tire be cheaper than the P(Passenger) tire? And what passenger car would fit these tires??
1- LT load range C- 2470
Another LT load range E- 3195 You can find out more about them on Goodyear web site, they also have Fortera Silent Armor I have some Goodyear coupons if you can use them.
The P metric designation does not mean they are designed strictly for cars. A lot or trucks are built with these. Usually a P metric will have a lower weight rating therefore it would ride a little softer and if you compared the two side by side you would find that the tread shoulder on the LT would be more square as opposed to the P.
Also the wider the tire the worse the traction in the winter time.. but doesnt look like that will be a issue with you..
correction on my part, 235 to 265.. your tire will be taller/not wider. But will still suck more gas..Also your speedo will be off.
This is from tirerack.com:
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86"
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Tim
The tire site:
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Fortera%20Tr ipleTred
It looks like the tire is way too big for my 17' rims. The picture doesnt do it justice and I cant seem to load up a pic of the tire itself:
[img]http://img352.imageshack.us/img352/7...t942007fq2.jpg[/img]
