Sponsored by: Auxito
Rust
Old Sep 11, 2007 | 08:06 PM
sdeforest's Avatar
sdeforest
Rust
I have a 97 and was wondering how much rust others trucks have. I live in michigan an some counties really drop the salt down in the winter. If you have rust, where is it. How is everyones door seams holding up. If you live in the north and your truck is not rusty, how often do you wash your truck. Thanks
Old Sep 11, 2007 | 08:31 PM
bigdaddyII's Avatar
bigdaddyII
My truck only has surface rust on the frame. I work around salt water but no body rust, just surface rust on the frame and tail pipes. I wash it maybe once a month through the automatic car washer.
Old Sep 11, 2007 | 10:49 PM
duggyb's Avatar
duggyb
only place i have rust is on the bottom of the doors on the inside and it is very very light....i could probabley repair it even.....i live in Canada.....and i wash and wax my truck about once a week in the summer...less in winter(but i purchased it with this rust....so it must not have been washed as much before i got it).
THNX
Duggy
Old Sep 12, 2007 | 07:47 AM
richard stone's Avatar
richard stone
I have bad rust happening on my left front quarterpanel of the bed and also my passenger side rear door is starting to rust through. My door seams are pretty bad too. It wouldn't be a ford if it didn't rust out!
Old Sep 12, 2007 | 08:07 PM
kharmaguru's Avatar
kharmaguru
Anyone know if this works?
http://www.counteractrust.com/counteract.htm
Old Sep 13, 2007 | 11:36 AM
Deebo's Avatar
Deebo
I had one of those systems put on my truck the day I bought it brand new.
No.. they don't work.
My right rear passenger door is rusting out on the under side of the door right at the seam.
Old Sep 13, 2007 | 03:49 PM
kharmaguru's Avatar
kharmaguru
figures. when it seems too good to be true...
Old Sep 13, 2007 | 10:19 PM
Turbo8's Avatar
Turbo8
Smile
I have friends that have tryed a product called Rust Bullet and they said it works.
Old Sep 14, 2007 | 12:01 PM
JOE SKI's Avatar
JOE SKI
I live in N E Pa and have lots of rust on frame,brake lines, spare tire, spring shackles (which I had replaced). I wire brushed & painted everything.
Old Sep 14, 2007 | 12:35 PM
Deebo's Avatar
Deebo
Where can you find Rust bullet?
Old Sep 14, 2007 | 12:58 PM
duggyb's Avatar
duggyb
yes i would like to know as well....is it expensive?...do you think it will solve the rust on the inside of my doors at the bottom seams?
THNX
Duggy
Old Sep 14, 2007 | 01:11 PM
sdeforest's Avatar
sdeforest
How many of you had your truck undercoated, mine isn't. There was a time a few years ago auto manufactures were saying there was no need for undercoating due to their manufacturing process. I'm starting to wish I undercoated because seams on the underside are beginning to rust and in my mind that is the beginning of the end. Not every seam has rusted but a few, I'd like to get rid it before it gets too bad.
Old Sep 14, 2007 | 01:29 PM
duggyb's Avatar
duggyb
yeah i imagine my under body is beginning to rust....but i am not to worried about it...i have 220,00KM on my truck..and by the time that rusts to a noticeable amount i will have another 100-150,000km on my truck and the rest of the truck will be falling apart.
but i would like to get my doors fixed becuase that could rust through and start to show.
THNX
Duggy
Old Sep 14, 2007 | 01:31 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
There is not one speck of rust on my '97, and we use salt every year on the roads here in VA.
Old Sep 14, 2007 | 01:57 PM
Deebo's Avatar
Deebo
I don't have rust any where else on my truck just under the passenger right rear door.
The bottom of my truck looks like the day it rolled off of the assembly line.
Pretty soon I'm going to bead blast the seam on the door and if I can find that rust bullet I will treat it.
