what do u think?
Old Sep 11, 2007 | 06:48 PM
peckhamjusten's Avatar
peckhamjusten
what do u think?
im gettin some new rims for my truck...its a stock 2wd f150. im just tryin to decide if i wanna mount 31x10.5 on it or stay with the stock size of 235,75-15. if u could put up or send me some links to help me out in my selection of choosin the tires to put on my truck it would b appreciated. thanks.
Old Sep 12, 2007 | 11:34 AM
Franklin2's Avatar
Franklin2
For a 2wd truck, I think I would go more for the hotrod look than the 4wd off road look. I would check into upsizing to something like a 245/70-15 or a 255/60/-15. Keeping the same height, but going wider with a wider wheel.
Old Sep 12, 2007 | 06:21 PM
peckhamjusten
good point, i was thinkin of that today while i was at work. but im not sure if i wanna just put wider on the back or all the way around?
Old Sep 12, 2007 | 10:20 PM
Franklin2's Avatar
Franklin2
You could do that too, and it looks pretty good. What people used to do is get about a 8 inch wide wheel for the rear, but it had a negative offset. They call it "backspace" now, and the wheel had very little backspace, so it set the wheel out, and run a 60 or 50 series tire on the rear. Then you run a normal backspace 6 inch wheel up front, with a 70 series tire up front.
Old Sep 12, 2007 | 10:24 PM
lwfox002's Avatar
lwfox002
Hey, I'm one of those "what people used to do". I had a '71 Ford LWB with 10" on the back and 7" on the front. I'd like to have that old truck back.
Old Sep 12, 2007 | 10:41 PM
85e150's Avatar
85e150
I'd look for 16 or 17" rims, maybe even 18s. Then use a lower profile tire like a 50 or 60, but not some huge Indy looking tire. Whatever comes stock on a new F150 for example. As for the old style look, yea, I remember that. But I'm more into tucked in with a reasonable ride height and not hitting fenders these days.
I put 31 10.50s on my e150...they are better than the old hard stockers, but next time, if there is a next time, I'll probably go to something smaller.
