Sponsored by: Real Truck
1999 F350 Speedometer problem
Old Sep 11, 2007 | 06:47 PM
LarryGaddis's Avatar
LarryGaddis
Hi All,
My 1999 F350 4X4 with the gas V10 hasn't been driven much (17000) miles. Last week I suddenly developed an intermittent problem where the speedometer/odometer stopped working. At the same time, the automatic transmission wouldn't shift properly and the truck was barely drivable. The next day everything was fine again. I'm wondering if it is the speedometer sensor in the rear end or some digital component up front. I'm only guessing, so any expert help is much appreciated. Thanks. Larry
Old Sep 11, 2007 | 07:17 PM
high ho silver's Avatar
high ho silver
Being it affected the speedo and tranny, you are probably correct. The VSS is your culprit. You may could just remove and clean it. The magnet will get caked up with small metal particles from the rear end and throw the sensor off. I did mine at 100k miles.
Old Sep 11, 2007 | 08:31 PM
Gofigurethis_01's Avatar
Gofigurethis_01
Mine actually went bad on me...
It was pretty cheap tor replace and easy to get to (right on top the differential)
Old Sep 12, 2007 | 08:29 AM
RogueSpear2023's Avatar
RogueSpear2023
I'd say it's you VSS, there pretty easy to fix. Unless you own a dodge ram like my buddy's, the rear diff, decided to eat the VSS sensor, they had to replace the whole rear end; do to all the little bits of sensor in the gears.
Old Sep 13, 2007 | 01:56 PM
LarryGaddis
Thanks to all who replied. I'll see if I can locate the VSS on the diff and swap it out, since that's the cheapest thing to try. I'm hoping it's not the PSOM or some other component that uses the VSS data.
RayFord88f150
Mar 2, 2012 06:35 AM
jdcrew
Apr 29, 2011 11:57 AM
dfarland
Sep 23, 2010 03:06 PM
paneltruck
Aug 16, 2010 09:33 AM
cvlngineer
1997 - 2003 F150
Apr 12, 2004 12:30 PM
