Crossmember difference
Old Sep 11, 2007 | 06:45 PM
oldmansimek's Avatar
oldmansimek
Is there a difference in the crossmember from a diesel or gas crossmember other than the removeable motor mount brackets. Iknow the deisel mounts right to the crossmember and all the gas motors mount on the brackets that go behind the crossmember.
Old Sep 12, 2007 | 11:37 AM
Franklin2's Avatar
Franklin2
I thought all crossmembers were the same, even for the sixes. I have never heard of anybody having to change frames for a diesel. The 4x4 f150 frame is different from a 4x4 f250 frame though in the front.
Old Sep 12, 2007 | 02:51 PM
hoxiii's Avatar
hoxiii
i've heard that the diesel truck crossmembers and core supports are toally different from the gas ones. I have no first hand experience with them, but i've heard it more than once.
Justin
Old Sep 12, 2007 | 09:42 PM
oldmansimek
The only difference in the gas crossmembers on all gas motors is the brackets. Except for if it had a 460 from the factory, the crossmember for the 460 has an indentation for the oil filter anyone planning on swapping should remember that unless you want to put a remote filter on. I just looked at the diesel crossmember it looks identical other then the motor bolts right on to the crossmember.
Old Sep 12, 2007 | 10:00 PM
82F100SWB's Avatar
82F100SWB
The diesel crossmember and the 460 crossmember are the same part. Thus, if you try and put the diesel mounts on a gas crossmember that has the oil filter cutout, you will have to build a bracket for the one bolthole that ends up sitting in the middle of the hole.
jniolon
13
Oct 29, 2012 07:25 PM
armyaviation
Oct 4, 2012 04:05 PM
19fifty4
15
Jan 21, 2012 11:25 PM
six7seta
Mar 2, 2005 12:09 AM
