Low idle
Old Sep 11, 2007 | 06:23 PM
KevinAH's Avatar
KevinAH
Low idle
I have an '04 s crew and over the past 3 days when at a light or coasting with no throttle the truck idles low. Not quite low enough to stall but close. Yesterday afternoon the check engine light came on so I took it to the parts store who ran the code. The code is a P0506 "Idle Air Control" RPM lower than expected. I purchased the idle air control valve and I was told that it should be near the intake but I cannot find it. Can anyone be specific as to it's location?
Old Sep 11, 2007 | 09:18 PM
KevinAH's Avatar
KevinAH
Fyi-There's 2 different valves for the
'o4. The dealership refers to it as a throttle position sensor (tps), not idle air control valve (iac).
Old Sep 12, 2007 | 07:58 PM
black04lariat's Avatar
black04lariat
IAC and TPS should be 2 seperate plugs. They are usually up around the throttle body.
neb0244
18
Sep 2, 2010 04:06 PM
SirRadiodude
Jul 24, 2010 10:55 PM
PITTF150
2004 - 2008 F150
Jun 9, 2010 10:35 AM
cbadgerjr
Bronco II
Oct 30, 2003 10:44 PM
tellec
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 8, 2003 04:43 PM
