cummins transplant?
Old Sep 11, 2007 | 06:06 PM
ponch37300's Avatar
ponch37300
cummins transplant?
I remember seeing some links to a website that sold the parts and also some links to articles on putting a cummins in our trucks. I did some searching but couldn't find what i am looking for. Does anyone have those links? thanks
Old Sep 11, 2007 | 06:17 PM
Badluck's Avatar
Badluck
fordcummins.com or check out www.destroked.com for all the parts
Old Sep 11, 2007 | 07:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If i were to do it, i'd do a Destroked kit
Old Sep 11, 2007 | 07:38 PM
stormyrider's Avatar
stormyrider
If you are putting a cummins in, before you install it, make sure it has the cam gear dowel pin mod installed or you may end up with some very expensive repairs. This was recently covered in Diesel Power Magazine, real problem with the Cummins.
Old Sep 11, 2007 | 07:40 PM
my79f's Avatar
my79f
oh yes make sure you check the killer dowel pin. and also the fifth gear nut on the nv4500 if you go five speed
Old Sep 11, 2007 | 08:12 PM
driximus's Avatar
driximus
You can get an adapter to go with whatever tranny you have especially if you already have a built 4r100.
Old Sep 11, 2007 | 11:24 PM
tholt34's Avatar
tholt34
Yeah depending on which cummins motor you install. The 12 valve motors had the killer dowel pin problem. The later 24 valve models, they don't say anything about those.
Old Sep 12, 2007 | 07:57 AM
SolidGround's Avatar
SolidGround
Don't be fooled...
This is a very extensive project. The 'kits' merely have motor mounts, tranny adapter plate and flywheel/flexplate. EVERYTHING else is in your court.
When I say extensive, it's just time consuming, there is no rocket science involved. Be ready to do alot of wiring and custom piping.
If you're using your tranny, tell it good bye for me. It won't last long.
My choice would be a 2nd gen mechanical 12v.
My .02
Old Sep 12, 2007 | 04:16 PM
ponch37300's Avatar
ponch37300
thanks everyone, that was what i was looking for. I was looking at putting in the 12 valve cause it is less complex then the 24. What years are the 2nd generation 12 valves? Does anyone know of a site "like" this one( i know there isn't any other site with this much info and freindlyness!) for the cummins engine? I would like to learn as much about it as i can before i start. Thanks again everyone. i am looking for a cummins right now and once i find the right engine i will park the truck and start and post lots of pics!
Old Sep 12, 2007 | 08:42 PM
elvia's Avatar
elvia
Here is a on ebay right now.
2001 Dodge Ram Cummins Diesel Engine Complete 5.9
http://cgi.ebay.com/ebaymotors/2001-...spagenameZWDVW
Old Sep 12, 2007 | 08:59 PM
DCSpecial's Avatar
DCSpecial
Check out the conversions forum here:
http://www.FTEs diesel forums.com/fo...splay.php?f=90
A handful of SD guys who've done or are doing the Cummins swap.
Also lots of Cummins info in the Dodge sections of the site.
Old Sep 13, 2007 | 05:52 PM
totin_tools's Avatar
totin_tools
Try this one helped my buddy out a few times. http://www.turbodieselregister.com/forums/
http://www.cumminsforum.com
Old Sep 13, 2007 | 05:59 PM
John311t's Avatar
John311t
If I ever do this im going with a CR, more work, but the power seems to be in the CR's court now.
Pitcrw6
17
May 28, 2024 10:49 PM
Eli1644
Feb 17, 2015 02:36 PM
joe f350
May 25, 2011 12:18 AM
motometal04F350
Apr 8, 2009 10:27 PM
phish555
Dec 6, 2008 01:28 PM
