Sponsored by: Auxito
Remote Turbo
Old Sep 20, 2007 | 06:18 AM
  #46
Sandbar Norm's Avatar
Sandbar Norm
Mr Dave,
My truck is a 97 5.4. I was thinking I could get a way with 8-9lbs boost with out any problems. Would a pair of the Chrylser TE04H be good for that? Can you adjust the built in wastegate? I to want to build a cheap setup as my funds are few. If they are real small, maybe I could replace the 2nd set of cats with them?
Old Sep 22, 2007 | 01:00 AM
  #47
shangopat's Avatar
shangopat
Banned
Is it safe to put this system on a stock 5.4 engine ? Or should there be more things to change ?
Old Sep 22, 2007 | 06:26 AM
  #48
Sandbar Norm
I think it is as long as you dont get to high with the boost. I been under my truck alot this week. Their is a lot of room to locate the remote turbo. There is not a lot of room to run the tubing to the intake without getting it to close to the exhaust. I think that a Procharger maybe the easer setup. Now the problem of finding one at 1/2 price. I seen one new and in the box on e-bay (sold) 2 weeks ago. It went for $2295.00. That would have been mine. I e-mailed the seller 3 times to see which F150 5.4L it fit. He never did reply.
Old Sep 22, 2007 | 08:51 AM
  #49
Mr Dave73's Avatar
Mr Dave73
Originally Posted by Sandbar Norm
Mr Dave,
8-9 lbs would be pushing it on those turbos.
Old Sep 22, 2007 | 09:34 AM
  #50
fast83's Avatar
fast83
alright I have decided for several reasons that I will go single turbo with methonal/water injection. I found a t3/t4 hybrid, surflo made for cat w/regulator oil pump all the plumbing for the oil pump, a walbrol 255 fuel pump, a 2 pod A piller with carbon fiber A/F meter everything for $325. I will build my own meth injection kit with a purge siliniod from a nitrous kit I already have and pvc 4" pipe for the resivor all I will need to complete the kit will be a pump and a mist nozzel. I will still need a boost gauge, a waste gate, bov, rail mount fuel regulator, cone filter, a flange for the turbo, and the cold side tubing along with a couple of silicone elbows so for another 500 bucks I should be able to have the rest of the stuff I need to do this build
D8chumley
2009 - 2014 F150
Nov 6, 2010 08:25 AM
AltaEx
Mar 29, 2009 10:15 AM
guiri
Mar 29, 2007 12:56 AM
jclj2003
16
Mar 18, 2005 12:25 PM
