6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGT gage install
Old Sep 11, 2007 | 03:12 PM
outlawdakota's Avatar
outlawdakota
EGT gage install
Has anyone installed one yet? I want to go pre-turbo I know on my 6.0 I went in the driver side manlfold. Can this work on the 6.4?
Old Sep 12, 2007 | 01:22 PM
Mac_Daddy's Avatar
Mac_Daddy
well i used to drive semi trucks with big caterpillar engines and the pyrometer or as you call it egt was allways after the turbo
Old Sep 12, 2007 | 02:18 PM
rob_nc's Avatar
rob_nc
The problem with installing the sensor on 1 side of a V configured engine is you lose half of the information the gauge could possibly tell you. What if you have an injector failure on the other side of the engine? Your pyro won't tell you this if your monitoring the wrong side. If you want readings pre turbine, it is best to take these readings just before the turbo where both exhaust manifolds converge into the turbine inlet.
