Sponsored by: Real Truck
HEAT/AC issue
Old Sep 11, 2007 | 12:03 PM
99-V10's Avatar
99-V10
HEAT/AC issue
Hello all,
This is my first post as I've just joined the forum. I recently purchased a 99 f-350 crew cab. I know I made a stupid mistake this but I never checked to see if the AC worked or the heater worked.
My questions are...
Can someone point me in the right direction to start diagnosing this? Is this a common problem? Is it an easy fix?
I can live without the AC but winters coming and I live in NH so heat is mandatory.
I will also be picking up a chilton's manual tonight.
Thanks for any help that can be provided.
Old Sep 11, 2007 | 12:22 PM
rugermack's Avatar
rugermack
Since both do not work, start with the fuses. Sounds like blower fan isn't running ?!!
Old Sep 11, 2007 | 12:29 PM
Sabre2th's Avatar
Sabre2th
Exactly what is it (or is not) doing? If it won't switch between modes, you may have a problem with the vacuum pump (or lines) on the passenger fender well.
Old Sep 11, 2007 | 04:16 PM
99-V10's Avatar
99-V10
The fan is definetaly working. I'm getting plenty of air movement, just no heat when its cold and no cold air when it's hot.
Old Sep 11, 2007 | 04:24 PM
99-V10's Avatar
99-V10
testtesttest
Old Sep 11, 2007 | 08:26 PM
SpringerPop's Avatar
SpringerPop
Check the heater hoses to ensure there isn't a valve in-line to shut off hot water flowing to the box.
When you switch from heat to defrost, do you hear a faint "thunk" in a second or so? That would be the position of the blend door changing. If not, start looking at the vacuum lines.
We'll need to know what engine you have, as if you have a diesel, the vacuum is from a different source.
We'll need to know if it's a four-wheel-drive, too, as the vacuum-operated hubs are prone to leaking, preventing vacuum from getting to the heater box.
Do you have flow out of the defroster vents only? That's a sure sign of vacuum loss.
There's a start for you.
Pop
Old Sep 12, 2007 | 11:49 AM
99-V10's Avatar
99-V10
vacuum lines
Thanks
It is a V10, 4x4, and yes there is plenty of air movement from the defroster. I will take a look at the vacuum lines as soon as I can.
Now that you bring that up do the manual locking hubs also have a vacuum line conenected to them?
Old Sep 12, 2007 | 05:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
I think what Pop is asking, do you get air out of the defrost as well as floor vents when you change the switch?
Old Sep 13, 2007 | 12:08 PM
99-V10's Avatar
99-V10
yes, the fan is blowing regardless what I select.
Old Sep 13, 2007 | 08:25 PM
zx250's Avatar
zx250
If the switch is moving the air flow from the defroster to the floor vent and the fan is running then you need to look elsewhere. The heat flows through the coil unless like Pop suggested, there has been a valve installed to turn the flow off during warmer season. If you don't have any cooling, sounds like you compressor is not working or you are out of freon. Look and see if compressor is working. Clutch may not be engaging correctly.
