I was wondering if anyone could run my setup on a desktop dyno. My high torque cam has 270 degrees intake duration and 280 degrees on the exhuast side. I am running c8ae-h heads and a 68 mustang 4 barrel intake off of a 428 it has the "S" on it, everthing else is stock
any help appreciated
thanx
Steve
Ashes to AShes
Dust to Dust
Without ch*vs
our tools would rust
I am running 9.0 compression and I am running a 650 holley with 2.5 inch pipes with homemade mufflers (basically straight piped) my cam is #2842 high torque cam from ertel manufacturing of canada, but here are all the specs
Cam lift
Intake: .201
Exhaust: .296
Sae duration
Intake: 202
Exhaust: 292
Sae timing
BTC 32 degrees
.50 duration
Intake: .204
Exhaust: .214
Lobe centers
Intake 104
Exhaust 120
Ashes to AShes
Dust to Dust
Without ch*vs
The event specs are on the cam spec card and are labeled IVO, IVC, EVO and EVC. I think the lift specs you have are incorrect. with a .201 cam lift you will only have a .354 cam lift which is way too small.
The specs in the cataloge say that the cam should have .484 valve lift on the intake side with .514 lift on the exhaust side, I just read what was on my cam box, and the numbers match (part numbers) from the cataloge to my cam so maybe there is a misprint on the spec card that is pasted to the cam box.
Steve
Ashes to AShes
Dust to Dust
Without ch*vs
Hey Ratsmoker have you forgot about me I really was looking forward to them numbers
1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it!
